Old 10-28-2006, 11:42 PM   #1 (permalink)
PoLiShPrInCe's Avatar
Anyone have Tein H-Tech's Installed?
Pics? Camber Issues?
Did a search but I could not come up with anything. Im thinking about the H-Techs because i dont want to bother with the camber kit and I have heard that you should get a camber kit with the s-techs... unless I am mistaken. Someone with the s-techs could help me out with the answer on that one.
PoLiShPrInCe is offline   Reply With Quote
Old 10-29-2006, 12:29 AM   #2 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
S-techs on my sedan. Been absolutely perfect so far and no camber kit either. A little bit of negative camber in the rear but not much different from factory. I say go for the s-techs, you might not even notice the drop with the H-techs.
Old 10-29-2006, 01:43 AM   #3 (permalink)
with s-techs your camber will be off but just as long as your toe is in spec, which you dont need a camber kit for, then your tires will be fine for a loooong time
subieguy83 is offline   Reply With Quote
Old 10-29-2006, 03:12 AM   #4 (permalink)
hmmm... maybe i should go with the s-techs then... the si ones have a 1.4 drop which would be sweet...
Old 10-29-2006, 05:29 AM   #5 (permalink)
oh and when i said ur camber will be off with the s-techs, i was only talking about the rears, it seems u can dump the fronts as low as possible and not need a camber kit
Old 10-29-2006, 06:15 PM   #6 (permalink)
hmmm s-techs for the si are 1.4 front and 1.3 rear drop and s-techs for the non-si are 1.15 front and 0.82 back... wondering which way i should go
Old 10-29-2006, 10:55 PM   #7 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
I went with the Si ones on my sedan.
TEIN S TECHS FROM CORSPORT blackhawk black si CorSport 7 04-27-2007 05:37 PM
Anyone Running Tein Flex? Type X Suspension and Brakes 12 12-22-2006 05:51 PM
tein SS VS Megan racing sickyute Suspension and Brakes 44 11-21-2006 06:54 PM
Tein SS coilovers sickyute Suspension and Brakes 19 04-19-2006 11:11 AM
Tein Basic vs. Tein SS? duy2006si Suspension and Brakes 2 04-18-2006 01:46 AM
