HP+ is almost a definite overboard here. The HPS is a very slight upgrade over stock. If you are running stock and they are not worn out yet, use them up first. If you wore out the stock, then the HPS is a good replacement.
How are the performance ceramic? I want a brake pad with good initial bite. I had axxis ultimates but they had way too much brake dust. Do the PC have better bite than the hos? Thanks
im in the market for some new brake pads as well....thinking of getting hps cause they seem to be at a good price and perform better than stock...im at 53k mi on my 08 fa5.
i hope i dont need to resurface the rotors cuz a lot of dealerships usually say to reduce break noise and warp rotors u should resurface your rotors wen u change out ur pads (if there is any rotors left to resurface) is tat true?
I run powerslot cryo treated rotors and hawk hps pads front and rear with russell stainless braided lines and ate blue brake fluid. Its slightly more aggressive than factorys. Their quiet and produce minimal dust. I will get a step above this next time i need brakes but need to do some research.
Related Threads
12M posts
157.4K members
Since 2005
