Old 10-09-2006, 09:35 PM   #1 (permalink)
8thcivic Sponsor
Z1 Performance's Avatar
Cusco Type 2 lower arm bar
Pics of the Type II front lower arm bar installed on our 06 SI:
There are 2 mods needed to install this brace as it is originally intended for the JDM Civic:
1) The exhaust hanger off the downpipe needs a slight modification - remove the rubber hanger and bend the lower hanger just above the upper hanger since this may interfere with the brace. Then, re-install the rubber hanger and you're all clear. I also have some stiffer exhaust hangers to test fit here to see if it will limit movement of the system here.
2) There is a small rattle of what I'm assuming is the cat-shield against the brace when the car is cold and you're moving from a dead stop and coming off the clutch. Once warm, the rattle is gone. A couple of small washers should provide enough clearance. I have an oil change to do this week so I'll remove the bar and see exactly what it's hitting.
I can post some better pics tomorrow - the sun was going down here hehe
Jonathan
www.z1auto.com
631-863-3820
Check out our BLOG for:
Z1 Performance is offline   Reply With Quote
Old 10-09-2006, 09:39 PM   #2 (permalink)
Why isn't it triangulated??? That is where the strength is.
Old 10-09-2006, 09:54 PM   #3 (permalink)
8thcivic Sponsor
Huh? It's a four point brace connecting the front subframe to the actual frame of the car.
Jonathan
www.z1auto.com
631-863-3820
Old 10-10-2006, 02:18 AM   #4 (permalink)
eugenekim.net's Avatar
captain obvious
it looks gorgeous
Old 10-10-2006, 02:49 AM   #5 (permalink)
shit is hot where did you buy it
hazeman is offline   Reply With Quote
Old 10-10-2006, 10:14 AM   #6 (permalink)
8thcivic Sponsor
We are the #1 volume Cusco dealer in the US so we got the bar first for fitting. PM me for details...
Jonathan
www.z1auto.com
631-863-3820
Old 10-10-2006, 10:26 AM   #7 (permalink)
airportguy770's Avatar
Dave
looks similar to the tanabe underbrace.
Originally Posted by Jrotax101
Apparently, I can't get it in the hole
^ Dave's BBQ 11/08
airportguy770 is offline   Reply With Quote
Old 10-10-2006, 11:17 PM   #8 (permalink)
Gunslinger's Avatar
What is it made out of?and are all the joints Tig'd?
Gunslinger is offline   Reply With Quote
Old 10-10-2006, 11:44 PM   #9 (permalink)
Aren't they aluminum? Hmm...this looks pretty nice. How's the ride improved? Also, is it just the picture or does the left side (in the foreground) on the bar look slightly bowed?
Official pics of the new Type R FujiBlueSi Garage 22 03-03-2007 09:48 PM
TANABE SUSTEC FRONT LOWER ARM BAR CIVIC COUPE 06+ mishima8 Suspension and Brakes 6 12-15-2006 12:03 PM
Honda Announces new Civic TYPE R Euro........... sfccrx Civic SI 2 09-16-2006 01:05 PM
Honda Civic Type R Europe. RODSCIVIC Garage 45 09-16-2006 02:19 AM
