Old 10-07-2006, 06:05 PM   #1 (permalink)
06blaksi's Avatar
Help.....installing springs
ok, I have my strut out and I can't for the life of me get that nut off the top. If I use an allenwrench I can't get a box wrench in there and if I use a socket I can't use the allenwrench....help...my car is in pieces!
Old 10-07-2006, 06:14 PM   #2 (permalink)
Black_civic_Si's Avatar
can you post ome pic of your process..? so i can see what you trying to do. I can help you more.
Black_civic_Si is offline   Reply With Quote
Old 10-07-2006, 06:19 PM   #3 (permalink)
06blaksi's Avatar
The center nut
Old 10-07-2006, 06:21 PM   #4 (permalink)
are you doing this by yourself and if the strut off the car i recommend having a friend around to hold the bottom strut while you using the box wrench. The way i did it i left the strut on the car first and using a 3/8 impact to take off that lil nut, then i took the strut down.
Old 10-07-2006, 06:23 PM   #5 (permalink)
06blaksi's Avatar
If I had an impact I'd be set. I got it so it will turn but the whole strut shaft turns with it. I really can't even squeeze a box wrench in that opening. I barely have enough for the socket
Old 10-07-2006, 06:24 PM   #6 (permalink)
yea if you have a air compressor machine around it be helpful. but from what i see from the pics lube it up with wd-40 let it sit ( minute) and have a friend holding the bottom end of the strut use the socket and do it fast.
Old 10-07-2006, 06:25 PM   #7 (permalink)
06blaksi's Avatar
I was reading about maybe holding the shaft with pliers. I'm scared I'll gouge up the shaft. For the other side, should I try to break it loose before removing it from the car?
Old 10-07-2006, 06:29 PM   #8 (permalink)
use a impact with a 3/8 adaptor on it and it should work. and you should have a friend to hold the bottom end with foot.. so basically have the strut on the floor one friend put his weight on the foot so it won't turn while you use a impact trying to pry it out. BECAREFUL the compress spring will try to force itslef out. while you feel the nut is coming loose stop and look how far it came out.
Old 10-07-2006, 06:32 PM   #9 (permalink)
06blaksi's Avatar
I don't have any impact tools, thats the thing
Old 10-07-2006, 06:32 PM   #10 (permalink)
you should try to break it loose before removing from the car.
Old 10-07-2006, 06:42 PM   #11 (permalink)
06blaksi's Avatar
ok...got it...thanks for your help....when I'm done, some rep points will be comin your way
Old 10-07-2006, 07:30 PM   #12 (permalink)
kool...if you need any more help just hit me up..
Old 10-07-2006, 08:54 PM   #13 (permalink)
06blaksi's Avatar
I got the front done. Too dark to do the rear tonight. Those should be easier by the looks of it. Thanks for the help. These look sweet. I can't wait until they settle a little bit
What about bumpstops? Do I need to cut them?
Old 10-07-2006, 09:06 PM   #14 (permalink)
Tien Ly
the best way of doing so is with air tools....i do it everyday since imma honda tech...quickest way is to lay the strut against a wall so u dont hurt urself or anyone else...and put an impact gun on n zap the nut off
aznbadboyz215 is offline   Reply With Quote
Old 10-07-2006, 09:13 PM   #15 (permalink)
the rear is gonna be easy but you will need need to compress the rear spring to pry it out, if you talking about the rubber cone for the rear you will need it. bumpstop? pics.
Old 10-08-2006, 01:18 AM   #16 (permalink)
caveman74's Avatar
Kevin
You need to cut the bump stops in half
caveman74 is offline   Reply With Quote
Old 10-08-2006, 11:17 AM   #17 (permalink)
stevenshizzle's Avatar
Steven
Hope you have a spring compressor.
stevenshizzle is offline   Reply With Quote
Old 10-08-2006, 11:52 AM   #18 (permalink)
BLU BY U's Avatar
did you have someone help hold your shaft?
Old 10-08-2006, 12:18 PM   #19 (permalink)
Si_on_my_back's Avatar
Too easy.
Si_on_my_back is offline   Reply With Quote
Old 10-08-2006, 12:20 PM   #20 (permalink)
BLU BY U's Avatar
i wonder who the designated shaft holder was.
pic of NEUSPEED RACE springs (sedan) on 17s 2006exsedan Suspension and Brakes 29 01-12-2008 06:53 PM
People with lowering springs... How are you stock struts holding up? DumbasSi Suspension and Brakes 41 09-02-2007 10:43 AM
Any Springs will fit? hoanger Suspension and Brakes 11 06-07-2006 01:15 AM
Looking for Tien S-tech springs in Vancouver Rpm2 Suspension and Brakes 8 05-15-2006 09:06 PM
Question on Installing Springs? larryd Suspension and Brakes 3 05-06-2006 05:21 PM
