Need honest advice on lowering springs - 8th Generation Honda Civic Forum
Old 07-03-2009, 08:43 PM   #1 (permalink)
07REGSI's Avatar
Robbie
For about 2 months I have been researching about lowering springs. I wanted some advice from owners that have used lowering springs, or coilovers. I have been looking into buying a set of skunk2 lowering spring and putting them on my stock struts. Than later on upgrade the struts, since I have heard that stocks hold up for a couple years.
Now my questions is it a waste? I have read on forums that some say its all looks, and doesnt really help handling. While others have said since it sets the center of gravity lower to the ground you have less body roll.
I also live in Pa where there is a good amount of pot holes and we do get some snow during winter time. I just would like to close the wheel gap and upgrade to some 18s with good tires. And have slightly better handling. I dont track my car just use it for every day driving.
What seems like the best lowering spring? As far as suspension and looks?
Just would like help on making a decision on others who know more and have had good or bad experience.
Thanks
07REGSI is online now
Old 07-03-2009, 10:41 PM   #2 (permalink)
Poweraide's Avatar
Stock struts might last a year. I have Progress and mine are ALMOST done. They were almost like stock in the beginning, then the struts started to fail.
Poweraide is offline   Reply With Quote
Old 07-03-2009, 10:52 PM   #3 (permalink)
07REGSI's Avatar
Robbie
wow really? I didnt think the wore that quickly...cause I saw a couple threads where the were on stock struts for 2-3 yrs before replacing them. And espcially makes me questions since skunk2 are a pretty good drop
07REGSI is online now   Reply With Quote
Old 07-04-2009, 12:03 AM   #4 (permalink)
UGA_SI's Avatar
A lot depends on road conditions and driving styles as to how long the stuts will last. They will slowly fail with time so for many people it's hard to determine if they are really gone until the start feeling the effects for awhile.
I know it's hard to do but I would recommend waiting until you have a complete setup (ie aftermarket springs and matching shocks or coilovers) rather than trying to skate by with lowering springs. This way, everything wears evenly and you only have to get into the suspension for install once.
If you want to close the wheel gap with 18's, the HFP suspension seems to be a good choice. 17's with the HFP isn't low enough for most but with 18's, the wheel gap almost dissapears. Plus, the suspension is from Honda and is cheaper and will last longer and will handle better than most spring/strut setups.
Good luck.
UGA_SI is offline   Reply With Quote
Old 07-04-2009, 12:09 AM   #5 (permalink)
07REGSI's Avatar
Robbie
Good luck.
appreciate the info. I was reading about how good the suspension is. They said it didnt drop as low as they wanted but the improved ride handling made it worth it all. How much is it by chance?
Cause if I do get spring and struts I dont know whats the best combination
Old 07-04-2009, 01:00 AM   #6 (permalink)
I've had my Eibach sportlines for about a year now. They are ok for daily driving for the first few months but afterward I regretted not getting the whole suspension. Daily driving can be rough, especially harsh and bumpy roads. Like others have mentioned, its a good idea to get a complete setup.
ir3ka is offline   Reply With Quote
Old 07-04-2009, 01:04 AM   #7 (permalink)
Xtreme Thunder's Avatar
Joey
My honest advice can be found in my suspension thread: Comparison: Stock Suspension vs. HFP Suspension vs. KONI/ Swift Springs Suspension
Xtreme Thunder is offline   Reply With Quote
Old 07-04-2009, 02:04 AM   #8 (permalink)
maximus20895's Avatar
Max
lowering springs do just that..lower the car..they are not made for better/same performance compared to stock.
I would get springs and shocks together.
maximus20895 is online now   Reply With Quote
Old 07-04-2009, 05:04 PM   #9 (permalink)
bulit184's Avatar
Razmataz
^^ i dont believe people when they tell me that it doesnt improve handling. i got pro kit on my si and there is no more body roll. very little if any. big difference in handling from before.
bulit184 is offline   Reply With Quote
Old 07-04-2009, 06:18 PM   #10 (permalink)
Baisa 11Bravo's Avatar
how can you tell if you blow out your shocks/struts?
Baisa 11Bravo is offline   Reply With Quote
Old 07-06-2009, 01:56 PM   #11 (permalink)
alinktothepast's Avatar
Logan
There will be a good amount of grease seeping out of them..
The struts went out on my old saturn and they knocked really bad when I hit bumps, the car was really sloshy and bouncy (not that it was much different when I replaced them... my saturn was crap).
alinktothepast is offline   Reply With Quote
Old 07-06-2009, 02:26 PM   #12 (permalink)
Joey
When the dampers no longer control spring oscillations.
-Bouncy, more than the typical single compression, rebound, rest sequence.
-Oil in the wheel wells.
-Annoying rattle over every bump, usually means the internal valving stack for the damper has exceeded its useful life.
One or more of those are signs.
Old 07-06-2009, 03:23 PM   #13 (permalink)
Ronnn's Avatar
lowering spring does provide some sort of performance improvement, it's not fair to compare a full setup...if lowering spring is waste of money, then why those company still manufacture lowering spring.
as lowering spring will lower your centre gravity, your car will have less body roll...
if you don't track your car, or only use it for DD and mainly want to lower the wheel gap, then you can go for the spring first and if the shocks blow out, replace them
even you get spring/shock combo, that doesn't mean the handling will be totally diff (because you only use it for DD), you won't even feel the real difference
and yes, some people did mention the lasting of the shocks depends on your driving style
if you don't track your car, your shock should last much longer
I had Eibach sportline with stock shocks with my previous EK3 Civic for 2 years, and nothing wrong with it
And then I changed to Tokico with H&R race spring, not a good choice, shock blown in a year
I also had experience with RSR lowering spring with stock shocks with my EK4
But I had Tein coilover for my current Civic, since i want to have height adjustability.....
Ronnn is offline   Reply With Quote
Old 07-06-2009, 08:33 PM   #14 (permalink)
2xSi's Avatar
Deleted
2xSi is offline   Reply With Quote
Old 07-06-2009, 08:34 PM   #15 (permalink)
2xSi's Avatar
No body roll..... take a look at this. Car has Prokit and Progress RSB.
Read my review of the Tokico HTS510 kit. Your best bang for the buck is full HFP setup. Unless you track or auto-x you can not compare the difference in performance.
Old 07-06-2009, 09:06 PM   #16 (permalink)
Joey
HFP still has body roll.
HFP still has areas to be desired, but for the price and being designed and produced by Honda is definately a plus over stock suspension.
Another option to Tokico HTS is KONI Sport dampers. HFP springs mated to KONI rebound adjustable dampers could give the driver more control over how the vehicle behaves on the track as well. Both have pros and cons. I required the damper to be at least rebound force adjustable, rebuildable and a company that offers custom valving services and KONI provides that for me.
As stated, full HFP is best bang for the buck. I had it for 35K miles and really enjoyed it, I just required further damper adjustment, especially in rebound forces, for my driving style.
A full race (consumer affordable) suspension for me would consist of:
-Redshift KONI D/A Height Adjustable coilovers (D/A meaning Double Adjustable; you adjust rebound and compression forces separately.)
-Eibach or Swift Racing coilover springs choosing my own spring rates.
If I tracked my car I would easily jump on that 2.5K suspension! Or just for the hell of it purchase it for my daily driver and order a set of higher rate springs and change out for race day.
Most like a simple DD set up though that reduces wheel gap and handles the street better than stock.
Again, can't go wrong with full HFP if you don't mind some wheel gap.
Old 07-06-2009, 09:36 PM   #17 (permalink)
2xSi's Avatar
XT, I agree 100%
I was refering to some one else stating that the Prokit has no body roll. That is me driving the NHBP sedan. The car had plenty of roll , more than stock and I did not feel there was an improvement in performance. It does have a nice drop, if that is what you are after. The ride on the street is smoother.
Old 07-06-2009, 09:45 PM   #18 (permalink)
Joey
Oh definately, the Eibach Prokit does not eliminate body roll, nor does my current suspension or HFP for that matter. Even my current suspension has areas to be desired, but I had to make the call on practicality and performance for a DD. Sacrifices were made.
Also, Progressive and Linear rate springs will react differently.
Wish I had the time to track my car, well, maybe I would if it weren't my DD, but that is my preference.
Old 07-06-2009, 09:54 PM   #19 (permalink)
sh33t_0f_p4p3r's Avatar
Tobie
i have 65k miles, and skunk2 springs for about 2k of them, they ride fantastic and look fantastic.
sh33t_0f_p4p3r is offline   Reply With Quote
Old 07-07-2009, 08:33 PM   #20 (permalink)
07REGSI's Avatar
Robbie
Lots of good useful information. I may still order a set of springs maybe skunk 2. And than order the struts in a couple months. Whats a good combo? Or best lowering spring for the drop and comfort?
Si owners i need your honest advice gameovamuttz Civic SI 55 01-27-2009 06:50 PM
Do lowering springs help? ProZach626 Suspension and Brakes 12 10-10-2008 07:41 PM
Lowering Springs! jethroooo Suspension and Brakes 2 09-12-2008 03:54 PM
skunk 2 lowering springs(Advice) lilvader Georgia 7 07-03-2008 08:31 AM
