09 Si, removing nut on top of strut to remove spring
I'm trying to remove the oem spring off the front strut on my 09 Si Sedan but I can't get the nut off of the top of the strut. The bolt takes an allen wrench but what am I supposed to use to turn the nut with? Am I making this too hard than it really is?
I used a power tool set at the highest torque/speed and the bolt came right off without using an allen wrench.
I know there is a special wrench with a weird bend that is used to turn the bolt while holding the strut with the allen wrench. Good luck |
Nathan
lol i had this same exact problem....i did my skunk2 pro-s in the parking lot of my dorms by myself.... i just rigged it and it was a huge pain in the ass. i used the impact socket over the nut and put a t-handled allen wrench down thru the socket....then used another allen wrench thru the release hole on the side of the socket. Mine were on DAMN good but with a little elbow grease n a lot of sweat it finally came off. with only one casualty..........
![]() CIVIC>CRAFTSMAN |
K I got them off. God damn they were tough. The left one I used a gear ratchet (pass through) and an Allen wrench and it came off. But the right one I had to take to walmart and have one of my buddies take off with an impact wrench. Crazy what a little compressed air can do lol. I still got the right rear to do in the morning and I'll be done. The rear isn't hard at all.
However the left rear looks higher than the stock right rear now. Any reason for this? Maybe the spring is in wrong? Thanks guys. |
| Removing stripped nut | 07K20Z3FA5Sedan | Mechanical Problems & Technical Chat | 8 | 06-10-2009 02:34 PM |
| DIY: Remove sag from shift boot and nut | blknytro | Do It Yourself Articles | 9 | 04-30-2009 01:42 AM |
| Question:Torque spec for strut tower 14mm nut | pigfragger | Suspension and Brakes | 3 | 02-27-2009 03:11 PM |
| NEED help removing a cross threaded nut | andywho | Suspension and Brakes | 8 | 12-03-2008 03:03 PM |
| Quick, need torque spec for top hat nut | asdf | Suspension and Brakes | 3 | 09-01-2008 12:36 PM |
