Removing rear shock/bump stop - 8th Generation Honda Civic Forum
Old 06-30-2009, 12:07 PM   #1 (permalink)
Can someone please tell me where I need to drill on the "crush sleeve" so I can get to the bump stop?
Here's a pic for reference...
ultra spikey is offline
Old 07-02-2009, 05:23 AM   #2 (permalink)
07NHBCivicSi's Avatar
Curtis
on both its at the top. On the fronts you take off the tophat and everything is revealed on the rears it should be under the rubber piece at the stop.
07NHBCivicSi is offline   Reply With Quote
Old 07-02-2009, 08:39 AM   #3 (permalink)
Xtreme Thunder's Avatar
Joey
On the rear, as pictured above, remove the rubber bushing piece if you haven't already. Slides right off. You see that collar just below the shocks threads? It should be slightly loose. It is the only thing that is keeping the black dust cover on. On the collar you should see a dimple. Use an appropriate size drill bit and drill out the dimple. After you have done that, the collar should slide off. You than can remove your dust cover, a washer type piece, and then your bump stop.
Xtreme Thunder is offline   Reply With Quote
Old 07-06-2009, 01:21 PM   #4 (permalink)
Thank you thank you thank you. Once I drill out that collar, can I reuse it?
ultra spikey is offline   Reply With Quote
Old 07-06-2009, 01:35 PM   #5 (permalink)
Joey
I know Eibach provides a new collar with their Sportline springs, being I have seen them installed before. Check to see if your spring manufacturer provides you with a collar, but in theory it should be able to be reused if needed.
When drilling, if reusing stock shocks, careful not to drill too far as there is a possiblity of marking up the shaft of the shock. Nothing that would hinder the performance or working of it, but keep an eye on that.
Old 07-06-2009, 01:38 PM   #6 (permalink)
Curtis
Drill slowly too. lol
do you really have to cut the bump stop when installing springs? Civic Pride Suspension and Brakes 34 02-03-2011 11:17 PM
Bump stop and ride height question trurice Suspension and Brakes 28 03-16-2009 01:22 PM
Rear Bump Stop Removal? Juice2Boost Suspension and Brakes 5 08-16-2008 09:29 PM
DIY bump stop removal..anyone? SIcivic07 Suspension and Brakes 8 09-08-2007 08:44 PM
Bump Stop Question bigbizznass Suspension and Brakes 3 05-09-2006 12:06 AM
