r18 / si sway bars interchangeable? - 8th Generation Honda Civic Forum
Old 06-29-2009, 04:49 AM   #1 (permalink)
wendell
just wondering if the sway bars on the r18 and si are interchangeable... i dont want to lower my r18 i just want a thicker sway bar .. my educated guess being in the honda game for a little bit is that yes they are interchangeable plus the fact the si n r18 share the same chassis... but i could be wrong. i did spend a little time with the search function and google... fyi
accord2civic is offline
Old 06-29-2009, 04:50 AM   #2 (permalink)
Cylestyne's Avatar
Asher
both the front and rear sway bars are changeable, please search, lots of people have done it.
Cylestyne is offline   Reply With Quote
Old 06-29-2009, 04:51 AM   #3 (permalink)
civicmarc's Avatar
Seņor Marcos
Welcome to the site!
civicmarc is offline   Reply With Quote
Old 06-29-2009, 04:51 AM   #4 (permalink)
wendell
accord2civic is offline   Reply With Quote
Old 06-29-2009, 04:51 AM   #5 (permalink)
sterizzle's Avatar
Sterling
yes they are
you just need mounting brackets
which, most people that upgrade there sway bars and want to sell their Si ones will sell you them with the bar
sterizzle is offline   Reply With Quote
Old 06-29-2009, 04:52 AM   #6 (permalink)
civicmarc's Avatar
Seņor Marcos
not enough time then.
Old 06-29-2009, 04:53 AM   #7 (permalink)
wendell
thx for the help... i will spend more time with the search function next time....
Old 06-29-2009, 05:13 AM   #8 (permalink)
CarDriver's Avatar
CollegeHillsHonda has everything you need in their Si front and rear sway bar kits.
For my 09 EX sedan, I ordered an Si RSB for around $80 shipped and all the brackets and bolts were included.
All you need to bring is a socket kit with a couple extension pieces, some lithium grease for the new fat rubber bushings, and some elbow grease. Oh, and maybe some WD-40. And definitely a jackstand kit.
I happened to have 2 metal ramps and I backed up onto them (with a friend to guide me of course--careful!), and then I used my 2 jackstands in front of the rear wheels as backup, then I blocked the front wheels in front of them and in back of them with some wood. I didn't actually use my floor jack (you know, the hydraulic pump jack with the lever).
A few screws will require some realllllly hard turning to get loose (the endlink screws if I recall, but you'll figure it all out. And for some reason the new RSB doesn't seem to line up, just flip it around. The first time around, it was bumping into my muffler and then realized that it was turned around the wrong way. Start in the morning while there's lots of light and give yourself plenty of time and you'll piece things together like a champ.
CarDriver is offline   Reply With Quote
Old 06-29-2009, 05:33 AM   #9 (permalink)
wendell
^^^^ thanks for the help i should have no problem installing it
im just worried about these mounting brackets talked about
I have a 2006 r18 sedan
so if i order the si anti sway bar... it should come with all the pieces i need.?
i ordered one for my 93 accord it was thicker than the suspension techqniques one.. but sold it a few weeks ago so never did an install.. im sure it would have been an easy install tho even without a lift.
im looking for the most bang for the buck..i dont care about if its jdm or a big namebrand...and i certainly dont give 2 f*cks lol if its a mugen part.
Old 06-29-2009, 05:34 AM   #10 (permalink)
sterizzle's Avatar
Sterling
i might even have one for sale if anyone is looking...
Old 06-29-2009, 05:38 AM   #11 (permalink)
wendell
hint hint... how much? pics?
Old 06-29-2009, 06:00 AM   #12 (permalink)
killak20z3R's Avatar
James Capps (amesoner)
dose anybody know if JDM FD2 sway bars will fit the FA5?
killak20z3R is offline   Reply With Quote
Old 06-29-2009, 09:06 AM   #13 (permalink)
Bryan
Take some time and search, somewhere there is a thread with all the part numbers listed with a description for each number. Thats the thread I used it all the part numbers were correct.
4ADAM12 is offline   Reply With Quote
Old 06-29-2009, 09:19 AM   #14 (permalink)
fox
fox's Avatar
2006-2008 Honda Civic Exterior Accessories for Sedan
scroll down until you find "front sway bar upgrade" and the rear one too. they will get you all the little parts to do it.
fox is offline   Reply With Quote
Old 06-29-2009, 10:16 AM   #15 (permalink)
Wegue Wegue
Cr8tive_leo's Avatar
Adrian
Obviously!
Installed Rear Sway on DX-G
Cr8tive_leo is offline   Reply With Quote
Old 06-29-2009, 12:41 PM   #16 (permalink)
CarDriver's Avatar
Do not spend any time learning about the different part numbers involved. Sure...you can, but you don't need to.
You go to CollegeHillsHonda's website (I think someone already provided the link), you look for their Si Rear Sway Bar kit (when I bought mine it was probably $65 + $18 shipping), and everything let me say it again in case I wasn't clear...
every bracket and tool and nut and bolt and bushing and everything you need is included in the kit.
Old 07-28-2009, 04:59 AM   #17 (permalink)
Andrew Nguyen
i gotta question, can the old bushing holders and and the brackets be reused?
Nahwhen_Andrew is offline   Reply With Quote
Old 07-28-2009, 01:48 PM   #18 (permalink)
fox
fox's Avatar
the bushings will probably be to small as there is a big difference in size of the bars. the brackets will need to be new as they are slightly different.
sway bars....? cambodianricer Suspension and Brakes 46 03-31-2008 11:13 PM
question: sway bars redline8500 Bolt-Ons And All-Motor 12 03-27-2008 10:12 AM
Sway Bars & AnTi Roll Bars b0y raceR Suspension and Brakes 7 05-11-2007 10:56 AM
SI sway bars Jay Kincannon Suspension and Brakes 0 04-02-2007 12:53 PM
strut bars & sway bars soymilk Suspension and Brakes 3 03-13-2007 12:26 PM
