Lubricating rear sway bushings - 8th Generation Honda Civic Forum
Old 06-28-2009, 10:45 AM   #1 (permalink)
SRLNCLT's Avatar
I'm ready to swap in the si rear sway on my lx. In all the instructions it says to lube the bushings, number 15/16 in the picture. How do I lube them? And what is best to use?
SRLNCLT is offline
Old 06-28-2009, 07:43 PM   #2 (permalink)
dorkiedoode's Avatar
Kevyn
i know you have to lube #11 where the brushing make contact with the sway on the inside.
dorkiedoode is online now   Reply With Quote
Old 06-28-2009, 07:57 PM   #3 (permalink)
SRLNCLT's Avatar
What do I lube that with?
SRLNCLT is offline   Reply With Quote
Old 06-28-2009, 08:05 PM   #4 (permalink)
Kevyn
White Lithium Grease
Old 06-28-2009, 10:06 PM   #5 (permalink)
CarDriver's Avatar
Yep, you can find Lithium Grease at any hardware store for a few bucks. Lube inside the black rubber bushings.
I actually forgot to lube mine when I upgraded my EX's RSB to the Si RSB and so far never had any noises or sqeaks...but sometime I should. Not sure if not being lubed will cause my bushings to dry out prematurely or something.
CarDriver is offline   Reply With Quote
Old 06-28-2009, 10:07 PM   #6 (permalink)
midnitesi's Avatar
james
just use astroglide
midnitesi is offline   Reply With Quote
Old 06-28-2009, 10:11 PM   #7 (permalink)
SRLNCLT's Avatar
^^I thought of that. But it seems after a while, that gets kind of sticky.
Old 06-28-2009, 10:13 PM   #8 (permalink)
midnitesi's Avatar
james
Old 07-10-2009, 08:09 PM   #9 (permalink)
SRLNCLT's Avatar
How about brake grease?
Old 07-10-2009, 08:24 PM   #10 (permalink)
xheartcore_boyx's Avatar
3bood aka Addy aka Bo dawood
Lithium grease, I used it on my progress bar, no more noises whatsoever!
xheartcore_boyx is offline   Reply With Quote
Old 07-10-2009, 11:41 PM   #11 (permalink)
SRLNCLT's Avatar
K I will get some. And I'm lubing inside number 11 where it contacts the bar? Anywhere else? Do I need to lube between #11 and the surface of the L bracket #13/14?
Old 07-11-2009, 12:05 AM   #12 (permalink)
CarDriver's Avatar
Just lube the inner hole of #11, the bushing.
Sway Bar Bushings s&mcivic2006 Ontario 3 05-07-2011 02:24 PM
People with experience with BE rear sway and Progress Rear sway TdotSi Ontario 8 05-11-2008 05:09 PM
