Old 10-05-2006, 01:55 AM   #1 (permalink)
spocheld's Avatar
Jeff
Question Drilled and/or slotted rotors?
Does anyone know if they make these yet? it's something that I thought of the other day that would be a simple upgrade.
spocheld is offline
Old 10-05-2006, 05:39 AM   #2 (permalink)
caveman74's Avatar
Kevin
Power Slot makes the slotted for the Si
caveman74 is offline
Old 10-05-2006, 06:28 AM   #3 (permalink)
aznchzexr's Avatar
Chester
Rotora slotted & drilled rotors
Battle Endless
aznchzexr is offline
Old 10-05-2006, 10:37 AM   #4 (permalink)
honda93's Avatar
Save your money, unless you want them for looks.
99% of street cars do NOT generate the kind of heat necessary to see an improvement in braking by using a slotted or drilled rotor. If anything, you are actually LOSING BRAKING EFFICIENCY because you have less surface area for the pad to work with. So again...
Anthony "Mario" Crea
NNJR-SCCA
honda93 is offline
Old 10-05-2006, 10:47 AM   #5 (permalink)
hmmmz...
bizzybearfigiblue's Avatar
Roberto
i like the looks, and i was also thinking about autox eventually
in case u don't know... http://www.8thcivic.com/forums/intro...-pix-here.html
For today's Entrepreneur... http://www.8thcivic.com/forums/group.php?groupid=48
Your spot for 8th's youtubers... http://www.8thcivic.com/forums/group.php?groupid=49
bizzybearfigiblue is offline
Old 10-05-2006, 02:04 PM   #6 (permalink)
rw_blaze's Avatar
well it would be a good upgrade if u do complete upgrade... i have rotora slotted/drilled.. with h6 rotora pads.. and rotora stainless steel braided lines and motul brake fluid....big difference especially track days...
rw_blaze is online now
Old 10-05-2006, 02:15 PM   #7 (permalink)
honda93's Avatar
Originally Posted by rw_blaze
...especially track days.
THAT's where you may start seeing benefits... On road courses.
Even autocrossing doesn't warrant the purchase or use of those rotors.
NNJR-SCCA
honda93 is offline
Old 10-05-2006, 05:08 PM   #8 (permalink)
MoDiFiEd
sickyute's Avatar
Marvie
AJP has stop tech slotted oem repacement rotors for the front and back...
i have them on my car now....been there for about 2-3 wks i think...no issues...
pics and info in this thread Slotted Rotors + SS brake lines
Shift when it blinks!
sickyute is offline
Old 10-05-2006, 05:17 PM   #9 (permalink)
venomous's Avatar
You don't need cross drilled or alostted rotors for track days. Perfect example, look at the civic si race car that raced in the 24 hour thunderhill. As Anthony mentioned, crossdrilled and slotted reduce the maximum contact that the pads enjoy on the rotors. The brake system on the si is well ventilated, so all you really need is good race pads, high temp brake fluid and stainless steel brake lines.
Save your money.
venomous is offline
Old 10-07-2006, 10:22 PM   #10 (permalink)
spocheld's Avatar
Jeff
I was looking more for a cosmetic upgrade than braking performance. I just like the appearance of the drilled and slotted rotors.
spocheld is offline
Old 10-09-2006, 08:44 PM   #11 (permalink)
aki
aki's Avatar
Resident Si Sedan Hater
Well the slotted rotors are usually larger in diameter, thus countering the loss in surface area (plus slotted area is very small). Unless on a track, chances are you won't see brakes fade anyway. Bigger rotors are nice--the biggest downside is the increased weight from larger rotors, though.
aki is offline
Old 10-09-2006, 08:51 PM   #12 (permalink)
F.I.A.T's Avatar
any of you guys every thought that and eftermarket rotors also might last longer overall and be more resistant to warpage....?
F.I.A.T is offline
Rusting Rotors ScorchedHands Suspension and Brakes 23 06-24-2007 01:05 PM
Rotora slotted & drilled rotors BattleEndless BattleEndless Performance 20 02-12-2007 05:56 PM
Opinions on Rotors rphinson Suspension and Brakes 10 06-23-2006 06:15 PM
Rotors smaller in rear... CaliGuy Suspension and Brakes 11 06-16-2006 01:07 AM
