Old 06-26-2009, 08:59 PM   #1 (permalink)
PRO Design Strut Tower Bars
Has anyone installed the PRO Design Strut Tower Bar for there si sedan in here? would it be a good strut bar to get? this is the strut bar Honda Civic PRO Design Strut Tower Bars at PRO Civic
it seems like it would be hard to install aswhile... i tried looking for a thread about installing a strut bar like the prodesign but no luck yet. does anyone know?
janleyto is offline   Reply With Quote
Old 06-27-2009, 12:29 AM   #2 (permalink)
or.. is there a DL or site for a service manual to take off the cover?
Old 07-10-2009, 09:37 PM   #3 (permalink)
xgrafcorex's Avatar
Brian
I just installed one today on my car. The general steps are simple, but the amount of room you have to work with makes it a pain in the ass. Once I managed to squeeze that thing in there..I had to take apart the whole bar (3 pieces, not including bolts, washers and nuts) to get the mounting brackets to seat properly on the bolts on the strut tower.
Once I had them both on there (not bolted down..though I guess you could if you wanted to.) I worked the bar back into the mounting brackets, reinserted the bolts and tightened them down a bit. That's when I decided to fully tighten down the brackets on the strut tower. After the brackets were secured, I finished tightening the bolts that came with the bar and reassembled the stock pieces of the car I unfastened.
It's pretty easy, but if you lose your cool quickly and just want to start smacking things with the hammer..then it is pretty annoying.
This thread gave me a good starting point as far as getting access to the area I needed.
DIY : Corsport Front Strut Bar
xgrafcorex is offline   Reply With Quote
Opinions on strut bars and lower tie bars Gixstars Suspension and Brakes 17 01-26-2008 12:53 AM
Strut Tower bars Uppers & lowers TOMMIELOEKO Suspension and Brakes 5 10-11-2007 01:20 AM
strut tower bars really work ! fg2!kid Suspension and Brakes 24 09-26-2007 01:03 AM
Aftermarket Sway, Strut and Tower Bars? FritozSI Suspension and Brakes 1 07-09-2007 07:47 PM
DX-G strut tower bars CivNick Suspension and Brakes 3 06-03-2006 03:07 AM
