Just installed 18" HFP wheels...now my rotors and calipers look awful - 8th Generation Honda Civic Forum
Old 06-26-2009, 11:10 AM   #1 (permalink)
QueenB's Avatar
Andrea
Ugh, just like the title says...
My rotors are all rusted and the calipers look dingy. I know I can paint the calipers but what do I do about the rust on the rotors?
I am trying to keep to a more clean look. Thinking a silver for the calipers. Can you have calipers powder coated?
QueenB is offline
Old 06-26-2009, 11:21 AM   #2 (permalink)
b464life's Avatar
Brandon Montgomery
You can paint calipers any color. I've got red ones with a black HONDA decal but the place I got the paint from has like 15 different color options.
b464life is offline   Reply With Quote
Old 06-26-2009, 11:44 AM   #3 (permalink)
QueenB's Avatar
Andrea
LOL, I will try to post some later. I have a Galaxy Gray.
QueenB is offline   Reply With Quote
Old 06-26-2009, 11:57 AM   #4 (permalink)
Si-Onara
JEA86's Avatar
Jeremy
paint them black i did and it looks alot better!
JEA86 is offline   Reply With Quote
Old 06-26-2009, 12:07 PM   #5 (permalink)
LikWidv1's Avatar
"NBA"
Only solution to the rusted rotors is replacing them. Do this before the rest starts sticking to your wheels.
LikWidv1 is online now   Reply With Quote
Old 06-26-2009, 12:10 PM   #6 (permalink)
QueenB's Avatar
Andrea
How involved is the powder coating process?
Which is better powder coating or painting?
I think I am going to stick with Silver for the calipers but I can't decide on PC or Painting.?!?!?!?
Can you sand the rotors and paint them after they have already rusted?
Old 06-26-2009, 12:12 PM   #7 (permalink)
quickfit's Avatar
Resident asshat
remove the calipers and send them to be powdercoated.
powder coating is more durable then painting
yes. its only surface rust on the rotors.
quickfit is offline   Reply With Quote
Old 06-26-2009, 12:12 PM   #8 (permalink)
illmaticone's Avatar
powder coating def.. i was quoted $125 at a few palces per 17 inch rim.. so that being said i cant imagine it will be pricey for all 4 calibers
illmaticone is offline   Reply With Quote
Old 06-26-2009, 12:17 PM   #9 (permalink)
QueenB's Avatar
Andrea
I read somewhere that you have to tear the complete calipers apart for powder coating. Is this true?
Old 06-26-2009, 12:20 PM   #10 (permalink)
^ good question... maybe you should take a lookg a college hills honda, they have HFP brake kit for about $450 or less i think
Old 06-26-2009, 12:23 PM   #11 (permalink)
QueenB's Avatar
Andrea
If I am correct... I think that is for an SI only
Old 06-26-2009, 12:29 PM   #12 (permalink)
quickfit's Avatar
Resident asshat
hfp brake kit is only pads and rotors. it doesnt replace calipers.
Old 06-26-2009, 12:32 PM   #13 (permalink)
QueenB's Avatar
Andrea
good point, but I still think that kit is for an SI only. I have an EX-L sedan.
Old 06-26-2009, 12:37 PM   #14 (permalink)
i think it works on the ex-l, ill see if i can digg anything up
Old 06-26-2009, 12:42 PM   #15 (permalink)
thats right!
Old 06-26-2009, 12:42 PM   #16 (permalink)
miketat594's Avatar
powder coating will last longer but you can always redo paint, or upgrade to an aftermarket caliper, imo black is the best color , doesnt show as much dust an grime as red an other colors..the rotor rust should clean up as you drive and if its the rust on the hats that your worried about then just get high temp paint and clean them well and paint them with a few coats and they will be good for a while..GL
miketat594 is offline   Reply With Quote
Old 06-26-2009, 12:49 PM   #17 (permalink)
jdm free's Avatar
AJ
are u sure they are rusted? or just bronzed a bit. use some simple green or some sort of good cleaner and it will help clean it up
jdm free is offline   Reply With Quote
Old 06-26-2009, 01:27 PM   #18 (permalink)
QueenB's Avatar
Andrea
I will take a picture this evening to post. I think it is rust.
Old 06-26-2009, 02:17 PM   #19 (permalink)
QueenB's Avatar
Andrea
Okay, my powder coater just called me back. He can do each caliper for $40.00 each. Unfortunately, It will have to be completely torn apart. ie: seals, pistons, etc. How involved is this process? The down time is not a problem because I do have a second vehicle.
Is there a caliper for sale out there that is already powder coated for around $200.00?
Old 06-26-2009, 03:47 PM   #20 (permalink)
spooned06civic's Avatar
chris
i have the perfect solution you can give me your hfp wheels and put your stock ones back on
spooned06civic is offline   Reply With Quote
Project Mu Rotors installed wiith Spoon calipers K20 SDN Suspension and Brakes 91 12-24-2007 03:02 AM
FS: Chicagoland 18" Honda Factory Performance HFP wheels w/ 215/40/18 Kumho SPT tires exbauer Mid-West 8 05-06-2007 06:53 AM
ASM EX Coupe, HFP 1" Drop, HFP 18" Wheels JVanBus Civic Coupe And Sedan 2 10-26-2006 09:08 PM
