help help help alignment specs? - 8th Generation Honda Civic Forum
Old 06-25-2009, 09:13 PM   #1 (permalink)
hey whats up guys i'm getting an alignment tommorow for my si i hace eibach sportline springs on it and they guy at the shop asked for alignment specs? does anyone know them or could i tell them to do it to stock with out to much wear on the tire?
chiv is offline
Old 06-25-2009, 09:15 PM   #2 (permalink)
Taylor Kurtz
read the sticky
CanyonDriver is offline   Reply With Quote
Old 06-25-2009, 09:27 PM   #3 (permalink)
the sticky on alignment describes what an alignment does and how to do it. I have no clue on what to say to this guy by reading that sticky. I just need specs ha plan out i don't even know if thats possible but yea
chiv is offline   Reply With Quote
Old 06-25-2009, 09:30 PM   #4 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
Specified Ranges for Alignment (LX/EX/Si)
Front (each side)
Camber (-0.5° to +0.5°)
Caster (6.0° to 8.0°)
Toe (-0.08° to + 0.08°)
Turning Angle Differential (-9.53° to -5.53°)
Front (cross or total)
Cross Camber (-0.6° to +0.6°)
Total Toe (-0.16° to +0.16°)
Rear (each side)
Camber (-2.3° to -0.4°)
Toe (+0.04° to +0.16°)
Rear Total Toe (+0.08° to +0.31°)
Old 06-25-2009, 09:34 PM   #5 (permalink)
is that stock?
Old 06-25-2009, 09:35 PM   #6 (permalink)
and if i print this out and give it to the guy will he look at me like i have four eyes? like can he work off that?
Old 06-25-2009, 09:40 PM   #7 (permalink)
Caper's Avatar
Those are stock ranges. He should understand them or he shouldn't be doing alignments.
Caper is offline   Reply With Quote
Old 06-25-2009, 10:38 PM   #8 (permalink)
okay thanks
Old 06-25-2009, 11:33 PM   #9 (permalink)
jasyatz's Avatar
As an alignment "tech" if you gave me that sheet..I leave the car the way it was. Those ranges are SO broad, the car would be all over the road..
Take this to him..
Front:
As much camber as you can get out of the front (you did get camber bolts right?)
zero front toe (it's safe and won;t wear out tires..good place to start with a street alignment)
Caster is non adjustable so don't worry about it unless it's more than 0.6 degrees different from side to side. If it is, you've got bigger problems than an alignment will solve.
Rear : If you have adjustable upper camber arms, get as LITTLE or close to -0.5 as possible. Trust me on this..Less in the rear is better Will help with handling and tire wear.
Rear toe: set it at 1/8" total in (1/16" in per side) (I know toe out helps the car rotate)..but I'm assuming since you are asking for specs, you don't want any surprises when you drive the car.
If you knew what to expect from a "performance alignment, you wouldn't have needed to post your question)..I don't mean to sound like an A*hole but...I answer this question far to often.
Start with what I gave you..Work with what you have..If you don't have front camber bolts, the front camber is what it is. If you don't have rear camber arms, it is what it is.. just set the toe as listed above and be done with it..
Hope this helps...and good luck with the service..
Last edited by jasyatz; 06-25-2009 at 11:37 PM. Reason: to make it more simple to understand
jasyatz is offline   Reply With Quote
Old 06-26-2009, 01:39 PM   #10 (permalink)
thanks for everything. but the shop just called and said my cars to low for the stand thing...
These are my wheel alignment specs... llckll Suspension and Brakes 0 12-06-2007 08:57 PM
Alignment places and specs jpv027 Suspension and Brakes 11 11-28-2007 07:25 PM
Specs for a wheel alignment llckll Suspension and Brakes 6 11-20-2007 07:58 PM
alignment specs ryanjacobson Mechanical Problems & Technical Chat 1 09-19-2007 09:41 AM
Alignment question (not specs) MDO677 Suspension and Brakes 4 08-24-2007 06:03 PM
