HELP! Skunk2 Coilovers Clunking noise??? - 8th Generation Honda Civic Forum
Old 06-24-2009, 11:17 PM   #1 (permalink)
sir]-[onda's Avatar
Fernando
Hey guys
i installed my skunk2 pro-s kit and ever since ive been getting clunking sounds from the front and rear.
sometimes i dont even go off a bump and i hear it when i brake...if i turn my wheel to one side i hear it..
has anyone had this issue or noises with this kit? the clunks are loud and honestly i cannot drive like this.
please HELP!
sir]-[onda is online now
Old 06-24-2009, 11:32 PM   #2 (permalink)
THURA FTW!'s Avatar
Thura
Bushings, check those and check your bumpstops.
THURA FTW! is offline   Reply With Quote
Old 06-24-2009, 11:34 PM   #3 (permalink)
civicmarc's Avatar
Seņor Marcos
sounds are normal for coils.
civicmarc is offline   Reply With Quote
Old 06-24-2009, 11:36 PM   #4 (permalink)
Ctownsi's Avatar
not normal for coils double check all bolts to start and then ches tie rods etc
Ctownsi is offline   Reply With Quote
Old 06-24-2009, 11:37 PM   #5 (permalink)
b464life's Avatar
Brandon Montgomery
normal for pro-s....mine do that and i have 3 friends that have pro-s and their's all do that
b464life is offline   Reply With Quote
Old 06-24-2009, 11:42 PM   #6 (permalink)
K20z3 Civic Si [PHONG]'s Avatar
Phong Nguyen
Make sure the top hats are tighten fully
K20z3 Civic Si [PHONG] is offline   Reply With Quote
Old 06-24-2009, 11:43 PM   #7 (permalink)
sir]-[onda's Avatar
Fernando
normal for pro-s??? are you serious..how can anyone drive with clunking noises? sounds like your car is falling apart!
i had coils on my old civic and never had any noise. so im sure that noise is not normal especially loud clunking noise!
was i suppose to use the bumpstops? i didnt use 2 of them.
sir]-[onda is online now   Reply With Quote
Old 06-24-2009, 11:44 PM   #8 (permalink)
THURA FTW!'s Avatar
Thura
How bad is the clunking noise? I know all types of coils "creak" a bit, but nothing like "BANG BANG".
Old 06-25-2009, 12:13 AM   #9 (permalink)
sir]-[onda's Avatar
Fernando
its loud dude and when it happens it vibrates the car.
this honestly sucks d/ck!
Old 06-25-2009, 12:18 AM   #10 (permalink)
THURA FTW!'s Avatar
Thura
Yeah dude, if it vibrates your car it is NOT normal. Check your top hat bolts and make sure your bump stops are in place.. I forgot to put the rears in when I put mine on. Good luck.
Old 06-25-2009, 12:25 AM   #11 (permalink)
Ctownsi's Avatar
im not trying to bash or anything but did one person do the install on all ur friends cars i have pro s on my car and dont have clunking noises so therefore i would say its not normal
Old 06-25-2009, 12:27 AM   #12 (permalink)
THURA FTW!'s Avatar
Thura
lol +1.
I know coilovers creak and make some light noises, but it shouldn't be to the point where your car is vibrating because of it or loud enough for you to go "wtf hit me".
Old 06-25-2009, 12:44 AM   #13 (permalink)
Phong Nguyen
Like I said above, it could be the top hats. A buddy of mine had Tein basics on his FA5 and he had the same problem. His buddy that installed them thought he knew what he was doing and didnt tighten the top hats all the way.
Old 06-25-2009, 02:39 AM   #14 (permalink)
Ayodog's Avatar
rori ( f*ck your form ) <3
sounds like the top hats up front arn't tightened. That'll lead to the spring being loose up front and make horrible noises. You're always going to have a minor amount of clunking in the rear of our cars due to the suspension setup with the spring by itself. The spring will get loose when theres no weight on it and make a clunk when it pops into place. And i guess check to top of the rear struts to make sure they were tightened down all the way.
Ayodog is offline   Reply With Quote
Old 06-25-2009, 02:40 AM   #15 (permalink)
DC King's Avatar
^^^ might not be seated right
DC King is offline   Reply With Quote
Old 06-25-2009, 11:44 AM   #16 (permalink)
sir]-[onda's Avatar
Fernando
Thanks guys
i will go through and make sure everything is tighten! i am hoping that is all i have to do. because when i first installed it and drove around it only had very very minor clunking but after 1 day it was clunking everywhere!
i live in cananda and Skunk2 doesnt have a 1-800 for support desk. i would really appreciate if someone in the states that doesnt get charged can call and as if clunking noise is common and maybe ask what possiblities could be causing this noise and then post it for me.
also how can you tell if a shock is blown?
thank you all for your feedback. ill keep you guys posted as 2morrow i will mostly have time to try 2 tighten everything.
Old 06-25-2009, 11:51 AM   #17 (permalink)
Johnold's Avatar
John
In my opinion, when installing coils, you have to check and retighten bolts and check your work again. It's kinda like torque down lug nuts, you drive 50 to 70 miles then come back and retighten or make sure everything has tigthened right and retorqued. check your work again man.
Think of it as you thinking you tightened everyone up REALLY REALLY REALLY GOOD and then you lower the car from the jack and back on the wheels and the weight of the car puts stress on the studs and pushes down to reveal even MORE thread for you to retighten.
Johnold is online now   Reply With Quote
Old 06-25-2009, 01:16 PM   #18 (permalink)
8thcivic Sponsor
Skunk2Brian's Avatar
Brian Nichols
The Pro S should not clunk when installed correctly. You most certainly should be using all 4 bumpstops as they are designed to prevent the dampeners from compressing further than they should. Removing the bumpstops can result in damage to the dampeners (as well as a voided warranty.)
I would recommend going through the installation again, paying particular attention to the upper mount assemblies.
Email BrianN@Skunk2.com and I will provide the most up to date version of the installation instructions for your review. If you would like to attach pictures I will be happy to try and troubleshoot your problem.
Skunk2 also runs an online HelpDesk through www.skunk2.com. Customers are welcome to post questions on that HelpDesk free of charge. We constantly check that HelpDesk so expect a response quickly.
Skunk2Brian is offline   Reply With Quote
Old 06-25-2009, 02:45 PM   #19 (permalink)
THURA FTW!'s Avatar
Thura
^+1
When I installed my coils, I forgot to put the bump stomps from the stock shocks onto the new ones causing loud banging noises, I put them on and the banging stopped.
Old 06-25-2009, 11:08 PM   #20 (permalink)
sir]-[onda's Avatar
Fernando
i looked at an excellent DIY on here and i noticed i never got the plastic washers.
if that is missing could that cause the clunking noise?
Clunking Noise During Braking.. SOLVED lineric Mechanical Problems & Technical Chat 10 04-27-2010 10:10 PM
clunking noise mick3ymik3 Mechanical Problems & Technical Chat 0 02-18-2009 09:28 AM
Loud Clunking Noise - Real Wheels Si8thGenSi Mechanical Problems & Technical Chat 0 02-12-2009 10:10 PM
clunking noise when releasing the clutch krazyguy187 Mechanical Problems & Technical Chat 1 02-12-2008 02:06 AM
AC clunking noise at startup FG Two Mechanical Problems & Technical Chat 7 07-13-2006 12:24 AM
