front shock top nuts
What size allan wrench is needed? Also, I've read an impact gun will work to take it off? Is this 100% correct? Because on older honda's I've lowered, the impact gun wouldnt always work, the shaft would just keep spinning. And finally, is the impact gun sufficient to tighten the nuts back on?
Never had a problem taking off any of the top hat nuts with a impact...never use a impact to completely tighten it. I always hit the nut a couple times with the impact then install it, once its installed it won't move when you tighten it so just torque it to spec.
| stock front top hat | damnu | Suspension and Brakes | 8 | 03-10-2009 04:38 PM |
| Tein SS coilovers shock damper setting front and back | indus | Suspension and Brakes | 8 | 06-26-2007 12:42 AM |
