OEM Camber Specs - 8th Generation Honda Civic Forum
Old 06-20-2009, 11:53 AM   #1 (permalink)
Jake
OEM Camber Specs
What are the limits of the adjustment of the stock camber on all 4 wheels. Without getting a camber kit.
Im heading for an alignment tody and I am curious.
Thanks
Civic Burgh 42 is offline
Old 06-20-2009, 11:54 AM   #2 (permalink)
Jake
2009 Honda Civic SI, forgot to put that
Civic Burgh 42 is offline   Reply With Quote
Old 06-20-2009, 12:13 PM   #3 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
Specified Ranges for Alignment (LX/EX/Si)
Front (each side)
Camber (-0.5° to +0.5°)
Caster (6.0° to 8.0°)
Toe (-0.08° to + 0.08°)
Turning Angle Differential (-9.53° to -5.53°)
Front (cross or total)
Cross Camber (-0.6° to +0.6°)
Total Toe (-0.16° to +0.16°)
Rear (each side)
Camber (-2.3° to -0.4°)
Toe (+0.04° to +0.16°)
Rear Total Toe (+0.08° to +0.31°)
Old 06-20-2009, 12:15 PM   #4 (permalink)
Jake
that camber is available in the stock parts?
Im curious cause I just put spacers on and I dont want to waste my time and money on the alignment if they arent going to be able to get it close to stock specs
Old 06-20-2009, 12:19 PM   #5 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
Those are the ranges from my last alignment at my Honda dealer. Copied everything you see right off the paper.
Old 06-20-2009, 12:21 PM   #6 (permalink)
Jake
Yeah thats the range that the settings need to be in. Im wondering what the ranges actually available on the stock components are. thanks for that info though
Old 06-20-2009, 12:25 PM   #7 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
There is essentially no camber adjustment in the rear, and I think the front has a small amount that can be adjusted.
Of course, that doesn't tell you what you want.
Old 06-20-2009, 03:15 PM   #8 (permalink)
BRIANxJDM's Avatar
Brian
would i need camber kit if i want to kind of slam my car with the buddy club n+
BRIANxJDM is offline   Reply With Quote
Old 06-20-2009, 03:42 PM   #9 (permalink)
Jake
yes you definitely would
As for my questions, Ive changed my path. Im not using the spacers, gonna try and sell em and Im going with a different wheel.
Old 08-28-2009, 04:27 PM   #10 (permalink)
I just got an alignment today after installing my HFP suspension and my rear camber was -1.8 on the right and -2.5 on the left. Everything else fell into proper oem specifications. Is this camber acceptable for a DD or will it destroy my tires in short order? Would i be able to get away with more frequent tire rotations or is a camber kit a better solution. I would rather not have to purchase a camber kit but if the camber will be a problem ill get one.
Bryan 07'CoupeEX is offline   Reply With Quote
Old 08-28-2009, 05:13 PM   #11 (permalink)
miketat594's Avatar
get the rear caber kit, your gonna eat inner tire pretty quick..
miketat594 is offline   Reply With Quote
Old 08-28-2009, 06:33 PM   #12 (permalink)
Debo's Avatar
Derick
I think you will be o.k. with those spec's. Just keep your tires rotated.
rear camber should be around -2.3 to -.4
TOE is what eats tires.
Debo is offline   Reply With Quote
OEM watt and ohm specs? benmunger I.C.E., Electrical, Security, & Navigation 4 10-26-2006 05:31 PM
can you go smaller wheel specs from oem? I NOE... CUZ I-VTEC Wheel And Tire Upgrades 4 10-01-2006 09:21 PM
OEM Wheel specs locofoci Wheel And Tire Upgrades 4 08-15-2006 04:12 AM
