rotor resurfacing? - 8th Generation Honda Civic Forum
Old 06-18-2009, 03:25 AM   #1 (permalink)
rotor resurfacing?
is it neccessary to resurface the rotors when changing the brakes?
allido is offline
Old 06-18-2009, 03:26 AM   #2 (permalink)
civicmarc's Avatar
Seņor Marcos
not unless yours are warped.
civicmarc is offline   Reply With Quote
Old 06-18-2009, 03:28 AM   #3 (permalink)
Zeuceone's Avatar
depends on the surface of the rotor. if it has tons of deep grooves in it then yes.
Old 06-18-2009, 03:28 AM   #4 (permalink)
how can i tell if it is warped?
allido is offline   Reply With Quote
Old 06-18-2009, 03:30 AM   #5 (permalink)
civicmarc's Avatar
Seņor Marcos
it would be obvious. Doesn't sound like yours is though.
Old 06-18-2009, 03:31 AM   #6 (permalink)
Zeuceone's Avatar
warped rotors sould be replaced
Old 06-18-2009, 03:33 AM   #7 (permalink)
ok my brakes started making screeching sounds like theyre scratching the rotor does that just mean i need pads. thanks i must sound like a noob, its just i never had a car make that sound.
Old 06-18-2009, 03:35 AM   #8 (permalink)
civicmarc's Avatar
Seņor Marcos
sounds like you just need new pads. I just replaced mine yesterday too
Old 06-18-2009, 03:39 AM   #9 (permalink)
thanks guys this forum is dope!!
Old 06-18-2009, 03:51 AM   #10 (permalink)
malditoron's Avatar
Ronald
Cost 20 bucks or less to get them resurfaced...i'd do it even if it wasnt warped...
malditoron is offline   Reply With Quote
Old 06-18-2009, 03:52 AM   #11 (permalink)
civicmarc's Avatar
Seņor Marcos
Welcome to the site!
Old 06-18-2009, 08:01 PM   #12 (permalink)
warped rotors should be replaced, not resurfaced!!
sidewindercivic is offline   Reply With Quote
Old 06-18-2009, 08:11 PM   #13 (permalink)
Admin Ninja
obert's Avatar
obert
I would just buy some new drilled and sloted ones !!!!
My Civic Feature On NW-Built
Old 06-18-2009, 08:12 PM   #14 (permalink)
wrecked's Avatar
Jason
whys that?.. lol
edit - to "sidewinder"
wrecked is offline   Reply With Quote
Old 06-18-2009, 08:28 PM   #15 (permalink)
because if they are warped, the amount it would take to resurface them could take the thickness down to an unsafe level.
I have heard that its not the best to resurface at all. So I just buy new discs when I do the pads. Its not like we change the brakes THAT often. Might as well do it all in one swoop and not worry about it for a while. Plus discs do not cost THAT much.
If you just resurface, there is obviously less mass in the disc. Less mass means it will be more prone to heating up faster/ hotter meaning it could lead to being warped again, faster/easier which can eat up your pads. F-it No thanks, I would rather spend my energy on mods then maint. When I do them I do pads and discs and am done with it.
I could be wrong, and I am sure I will get flamed, however thats how I do my breaks and my spin on the matter.
Blk_07_SI_Sedan is offline   Reply With Quote
Old 06-18-2009, 08:53 PM   #16 (permalink)
wrecked's Avatar
Jason
no. Every rotor has a minimal thickness spec. Most OEM rotors can be resurfaced several times before they will get below that spec. Usually, resurfacing or (cutting, as we call it) rotors only requires taking a few thousandths off.
Old 06-18-2009, 09:38 PM   #17 (permalink)
Chase016's Avatar
Brandon
I reccomend resurfacing the rotors any time you will be putting new pads on that way you can have perfect coverage from pad to rotor for the break in period.
Chase016 is offline   Reply With Quote
Old 06-19-2009, 01:46 AM   #18 (permalink)
using a dial indicator and checking your measurements to factory specs. If it's warped more than the factory limit then resurface as long as you don't go close to minimum thickness.
sleeper_civic is offline   Reply With Quote
Old 06-19-2009, 02:03 AM   #19 (permalink)
vipertag313's Avatar
Scott
or you could go on the interstate and break from 70-55 and see if your car shakes really really bad... thats how i found out mine were warped
vipertag313 is offline   Reply With Quote
Old 08-03-2011, 11:31 AM   #20 (permalink)
Tongman's Avatar
Does resurfacing the rotors require the rotors be taken off? So a reasonable resurfacing job is about $20?
Tongman is offline   Reply With Quote
Need help, frozen rotor set screw, what to do? 20civic07 Mechanical Problems & Technical Chat 8 05-10-2009 12:36 AM
Resurfacing Brake Rotors vipertag313 Suspension and Brakes 17 03-31-2009 01:26 AM
Brake Rotor Change.....NEED HELP!!!! racerx78 Suspension and Brakes 21 03-30-2009 02:48 AM
Disc rotor cleaning 8thgenuser Detailing 14 05-07-2006 01:27 PM
