Old 10-03-2006, 01:45 AM   #1 (permalink)
Nox
Exclamation Help ! Coilover install!
Anybody have pics of the rear install on megan coilovers? Fronts just perfect, but I am unsure of how the rear shock hardware is installed. Got them both torn apart, but it is very dificult to get the shock installed up top. Once I get them installed the suspension is so tight that mty rear whell will not touch the ground. I have them set at maximum height so that is not the issue. I am thinking my washer sleeve install is wrong!
Nox is offline
Old 10-03-2006, 03:28 AM   #2 (permalink)
Nox
I got part of the issue fixed. The wheel will sit on the ground. The jack was let all the way down, but the car lowered enough that it will sitting on the jack in the lowered position.
Anyway.... still not clear on how to mount the rear strut. Does anyone know if you use the factory rubber stops up top?
Nox is offline
Old 10-03-2006, 07:14 AM   #3 (permalink)
Black_civic_Si's Avatar
are you talking about the black rubber cone as a rubber stuff, if so yes
Black_civic_Si is offline
Old 10-04-2006, 09:26 PM   #4 (permalink)
Here is a pic of the rear form an install that we did.
Ben10 is offline
Understanding Springs and Coilover? kenken3686 Suspension and Brakes 15 01-30-2008 06:21 PM
install aftermarket radio on DX sedan jamieZ Civic Coupe And Sedan 12 01-17-2007 09:08 PM
How do I install the HPF front lip for the 06 Si CIVI7 Civic SI 2 09-18-2006 02:32 PM
Megan Racing Coilover Damper kit SPECIAL FOR CANADA members ONLY BattleEndless BattleEndless Performance 0 09-09-2006 12:26 PM
IMG install?!? SonicK20Z Bolt-Ons And All-Motor 1 06-21-2006 05:45 PM
