Old 06-05-2009, 08:19 PM   #1 (permalink)
Alvaro
Question what is exactly the camber kit for?
hey, i have a doubt... i'm also using lowering springs on my car but dont have the camber kit... what is exactly the camber kit for?
thanks
ALVARO_MC is offline   Reply With Quote
Old 06-05-2009, 08:22 PM   #2 (permalink)
thisisdudewhoru's Avatar
I'm brian and I'll kill you.
Adjusting the camber of the wheel.
thisisdudewhoru is offline   Reply With Quote
Old 06-05-2009, 08:26 PM   #3 (permalink)
Alvaro
Does having it or not the kit makes a difference or is it just for backup?
Old 06-05-2009, 08:28 PM   #4 (permalink)
#1 Post Whore
07mugencivic's Avatar
ToE kNeE
eat out your tires
Originally Posted by 0720Steve View Post
we should rename : beer: to :tony:
Originally Posted by Vroom View Post
maybe for u to strip....
Old 06-05-2009, 08:29 PM   #5 (permalink)
El Come Verga
helps ur tires last longer...
streetlunatic08 is offline   Reply With Quote
Old 06-05-2009, 08:30 PM   #6 (permalink)
Alvaro
thank you all !!
Old 06-05-2009, 09:05 PM   #7 (permalink)
Alvaro
one last question... the camber kit goes rear and front?
Old 06-05-2009, 10:32 PM   #8 (permalink)
you have to buy the camber bolts for the front...and the camber arms or the ingalls adjustable brackets for the back.
Old 06-05-2009, 11:03 PM   #9 (permalink)
miketat594's Avatar
if you want to be able to align it , you will need these items
miketat594 is offline   Reply With Quote
Old 06-05-2009, 11:13 PM   #10 (permalink)
Djel's Avatar
geez..
Camber kit is useful only when you're not able to reduce negative camber correctly with stock adjustments.
Camber will NOT wear your tires faster unless you only drive in straight line (-2.5° and less is fine..)
Camber kit is not needed for mild drop.
Zero front camber will kill your handling.
Djel is offline   Reply With Quote
Old 06-05-2009, 11:32 PM   #11 (permalink)
Xtreme Thunder's Avatar
Joey
People who get camber kits either:
1. Want better handling characteristics, so they dial in a more aggressive custom alignment; ie. more negative camber in the front than the rear. Some even add to a stock suspension, for that same reason. Custom alignment to dial out some of the factory understeer. Reduces inside tire tread life. Frequent tire rotations suggested.
2. Want stock alignment specs so tires wear as if still running stock suspension.
3. Using a rim width and offset that forces one to need to run more negative camber.
4. Combination of 1 and 3.
Xtreme Thunder is online now   Reply With Quote
Old 06-06-2009, 11:39 AM   #12 (permalink)
# 1 Friend Whore
obert's Avatar
Robert
Camber======= BAD FOR TIRES !!!!!!!!!
Old 06-06-2009, 01:38 PM   #13 (permalink)
miketat594's Avatar
Originally Posted by Djel View Post
geez..
uhhh..no incorrect..a 2.5 neg camber cuts tire life by 25%, and as for alignment issues hondas come with NO rear adjustment. So if the car is lowered you are throwing the alingment off a good bit. On top of that a basic lowering kit offers between 1 an 2 inches of drop which can throw a car off by as much as -5 degrees of camber which now would shorten life to 50%, along with the fact that honda had issues with people having abnormal tire wear right from the factory, in which some people were buning up tires in less than 5,000 miles due to the rear control arms. Up front alignment bolts are smart since I run -1 and with coilovers with the stock settings couldnt get in that far, I had to use them....so your info is wrong..
When To Use Camber Kits?/do I Need A Camber Kit? Highrev1 Suspension and Brakes 340 03-09-2010 12:29 PM
Too much negative camber? Front camber kit review aki Suspension and Brakes 11 06-20-2008 02:26 AM
