rear sway bar issue.. =\ - 8th Generation Honda Civic Forum
Old 06-01-2009, 10:15 PM   #1 (permalink)
So I just installed the progress rear sway bar. I have SPC rear control arms and it makes contact with the control arms.. It also contacts my muffler. Do you guys have any advice as to what I should do? Will adjustable end-links solve my problem?
jwb6658 is offline
Old 06-01-2009, 10:26 PM   #2 (permalink)
Xtreme Thunder's Avatar
Joey
Sounds like it was installed incorrectly.
Xtreme Thunder is offline   Reply With Quote
Old 06-01-2009, 11:11 PM   #3 (permalink)
Tony D
Sounds like you may have the bar mounted upside-down. It will bolt on both ways. This is a common problem, but easy to fix. I hope this helps.
Tony D
NewEdgePerf is offline   Reply With Quote
Old 06-01-2009, 11:45 PM   #4 (permalink)
I can't believe I did that!! I literally had it flipped in 15 minutes after I jacked it back up.
jwb6658 is offline   Reply With Quote
Old 06-02-2009, 01:58 AM   #5 (permalink)
trickyazn's Avatar
yup.. installed wrong.
Vancouver Honda and the Sway Bar Issue Verviticas BC, Yukon, & NWT 45 06-02-2010 05:24 PM
What is the difference & benefits between a rear sway bar and a lower rear tie bar? irichard Suspension and Brakes 12 08-13-2009 10:58 AM
JUST installed my Raybrig rear fog light and my si rear sway bar mistergizmo007 Introduction & Pictures 55 03-13-2009 02:12 PM
noise from rear... hfp suspension and progress rear sway bar rippars Mechanical Problems & Technical Chat 8 07-01-2008 09:42 PM
Roll Call! Who with a non-Si has upgraded the rear anti sway bar? Si bar fits LX? Andrei'sCivic Suspension and Brakes 13 07-01-2008 05:07 PM
