darryl
front camber bolts
im getting these and i wanna know with only one set which hole do you prefer it to go in....bottom or top cus im seeing half the people say top and the other say bottom.i know there are reasons why its one or the other but which is best and safest? thanks.
The top is preferred but often doesn't give enough negative camber by itself. That's when people choose to use the bottom hole for the crash/camber bolt or use two, one in each hole. I would try to get by with as few changes from stock as possible. I just wouldn't feel comfortable with two bolts on each each side but YMMV.
#13 (permalink) |
Judd
I placed it on top. Immediately felt a difference. I went 3/4 turn. If the piece that sticks out is installed facing away from the tire, it's negative according to the instructions. We did loosen up the lower bolt a bit to get easier movement.
| Front Camber Bolts | bscott52789 | Suspension and Brakes | 7 | 12-27-2007 07:35 PM |
