I have them and they work great. If you are unsure of how to install them than I would suggest paying someone to install them. Just in case here is a DIY
DIY: SPC Front and Rear Camber Kits |
Austin
I had skunk2's and I've switch to SPC now... being able to adjust your alignment without disconnecting the camber arm saves ALOT of time at the alignment shop. Considering you're probably paying upwards off $100+ just in labour getting alignments done over teh next couple years... definelty worth it IMO... its a shame that they don't make all rear camber kits like this one.
#11 (permalink) |
You might get a better alignment out of them since they are easier to adjust (you don't have to take the arm off to adjust them). How accurate the alignment actually is really depends on the guy doing your alignment.
#18 (permalink) |
good camber arms, the DIY on here is for the old camber arms and is slightly different than the new ones. So make sure you know exactly what to do with the new ones before starting this. you will also probably need breaker bar, mine only had 12000 miles when installed the SPC camber arms and the old ones were a pain to get off, luckily my friend had his breaker bar and we got it off.
#20 (permalink) | |
If it's not adjustable, what the hell was the point of the arm? The SPC arms, the old style solid looking ones, were adjustable without taking them off the car as well. |
