spc rear camber arm - Page 2 - 8th Generation Honda Civic Forum
Old 05-30-2009, 12:07 PM   #21 (permalink)
liquidr1's Avatar
Dustin
Why do you guys keep saying the old ones arent adjustable. I have no problems aligning my old style spc arms.
liquidr1 is offline   Reply With Quote
Old 05-30-2009, 01:06 PM   #22 (permalink)
bump for my question
deotherhalf is offline   Reply With Quote
Old 05-30-2009, 03:28 PM   #23 (permalink)
angeloHC07's Avatar
anybody have a link where to buy the new spc camber arms?
angeloHC07 is offline   Reply With Quote
Old 05-30-2009, 10:47 PM   #24 (permalink)
Ubetit's Avatar
Originally Posted by deotherhalf View Post
Incorrect. The larger nut is used to control the camber.
Make sure both nuts are against the arm. While holding the outer nut (jamb nut) and bushing from rotating, turn the larger inner nut until until the overall length of the arm matches the length of the stock arm. When you do this they both lengthen. It's hard to visualize it so just try it. Install them. Tighten the outer jamb nut against the inner nut. Tighten the pinch bolt on the arm to keep the camber from changing. Take it to an alignment place.
I installed mine yesterday and had it aligned an hour later. The car feels tight as hell now with the hfp suspension and alignment. Progress rear bar goes on if i need the rear end to rotate a little better. I didn't have to explain my setup at all to the guy that did my alignment, I watched him and he knew right what to do. He said these arm are easier to adjust than a lot of other kits he's seen. The main problen is that you need some big wrenches. I think the large nut is a 32mm and the biggest I had is a 24.
Ubetit is offline   Reply With Quote
Old 05-31-2009, 05:48 PM   #25 (permalink)
fsxbob's Avatar
what Ubetit said. Hold the "big ball thing" still, it shouldn't rotate. use your hands to rotate the large nut to the correct length. since the threads are opposite, both will come in or out depending on which way you rotate the large nut. when the length is set, just lock down the small nut and the pinch bolt.
to install, you only need a wrench big enough to tighten the small inner nut, the alignment tech will take care of the big inner nut. Its an easy install
fsxbob is offline   Reply With Quote
Old 05-31-2009, 11:33 PM   #26 (permalink)
angeloHC07's Avatar
Old 06-01-2009, 12:08 AM   #27 (permalink)
IT GUY's Avatar
Ben
CorSport Online Store: Honda - 06+ Civic - 67470
IT GUY is offline   Reply With Quote
Old 06-01-2009, 02:51 AM   #28 (permalink)
angeloHC07's Avatar
Originally Posted by IT GUY View Post
thanks
Old 06-01-2009, 03:50 PM   #29 (permalink)
Hondarize's Avatar
i'm planning on getting these too. Is the front camber necessary? on a 1.5'' drop? do you have the front ones too? How's the tire wear with out them?
Hondarize is offline   Reply With Quote
Old 06-01-2009, 08:19 PM   #30 (permalink)
VanSin23's Avatar
Van (08 ASMFA5)
might as well get the front bolts while you are doing it just to be safe for camber.
VanSin23 is offline   Reply With Quote
