Old 09-21-2006, 01:28 PM   #1 (permalink)
rw_blaze's Avatar
Brake caliper swap...
ok i've been tracking my lx coupe and looking into upgrading brakes.. nothing big and something with a lil more kick. So i will be getting rotora slotted/drilled rotors for Si.. would i be able to swap my calipers to an SI or even rsx type-s calipers... or even TL calipers...
so basically im juss looking at upgrading to bigger OEM caliper that would work without much modification...
rw_blaze is offline   Reply With Quote
Old 09-21-2006, 02:39 PM   #2 (permalink)
You don't need a larger caliper. The OEM's work fine. Put the money into stainless lines, upgraded pads and high-performance brake fluid.
Old 09-21-2006, 02:47 PM   #3 (permalink)
O6 Si's Avatar
Luisē
what does stainless lines accomplish?
O6 Si is offline   Reply With Quote
Old 09-21-2006, 02:55 PM   #4 (permalink)
Factory lines are usually made from rubber. Rubber lines expand when heat passes through them and power that would've been used to brake is dissipated. Stainless-steel, teflon-coated lines do not expand, therefore no braking power is lost.
Old 09-21-2006, 04:14 PM   #5 (permalink)
CivicWithNav's Avatar
and you can't just put SI rotors on urs...
totally different setup
Old 09-21-2006, 04:32 PM   #6 (permalink)
Toxis's Avatar
Even Women Aren't Safe
is the brake fluid JDM? I hear they add more stopping hp.
Toxis is offline   Reply With Quote
Old 09-21-2006, 07:04 PM   #7 (permalink)
el_ben2's Avatar
so youre saying that the stock si rotors fits in the LX/DX/EX?? also the calipers?
so that, in fact, told me that i can put a bbk of the si into my ex?
el_ben2 is offline   Reply With Quote
Old 09-22-2006, 09:44 AM   #8 (permalink)
rw_blaze's Avatar
well if u get a BBK it would come with all the necessary hardware u need and 4 piston calipers... so technically u can juss easily swap..
Old 09-25-2006, 12:20 PM   #9 (permalink)
O6 Si's Avatar
Luisē
thnks skittles i shoulda pulled that together
Brake caliper question pickle430 Wheel And Tire Upgrades 17 10-31-2008 09:25 AM
Brake Calipers? hoanger Suspension and Brakes 1 06-20-2006 10:27 PM
Si spoiler swap, has anyone done the light too? TommyD Inside and Out 9 06-17-2006 01:16 PM
Anyone with parking brake problems? Silver06 Garage 7 12-16-2005 02:18 AM
