Old 09-20-2006, 10:00 PM   #1 (permalink)
CivicWithNav's Avatar
"oem" big brake kit
my friend has a Jetta VR6 s/c'ed
and he's got a big brake kit. it's uses an OEM Pads and Caliper but uses bigger rotor. what it does is, it relocated the caliper further out, with bigger rotors, it has more surface area to grab.
does anybody make kit like this for civics yet?
I thought that looked pretty cool and a cheap way to go big brake!
here's a pic of it
Old 09-20-2006, 10:08 PM   #2 (permalink)
aodmisery's Avatar
MEOW!!
i think powerslot does the same thing bigger rotors and relocates the caliper outward dont know if they have a set available for the si yet though
aodmisery is offline   Reply With Quote
Old 09-20-2006, 11:05 PM   #3 (permalink)
Many choices, but the 2nd one would be the easiest.
http://fastbrakes.com/shop/index.php?cPath=28_165
DumbasSi is offline   Reply With Quote
Old 09-20-2006, 11:13 PM   #4 (permalink)
Tuna Fiddle™
twistedframe's Avatar
Dave
I don't think it actually gives more area to grab since you are using factory sized pads and calipers. What it does is give you more material to disipate the heat quicker. Since it takes longer to make a complete circle after it hits the pads it gets a longer chance to cool down.
Old 09-20-2006, 11:13 PM   #5 (permalink)
Powerslot has them and so does Wilwood (fastbrakes).
Another option is the Acura RSX A-Spec brakes.
Old 09-20-2006, 11:20 PM   #6 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
Thought A-Spec was only an aesthetics-like option.
Old 09-20-2006, 11:22 PM   #7 (permalink)
Given enough time, someone will figure out a DIY on how to install Ridgeline brakes on the Civic.
On the otherhand, the Si's brakes are a decent size already. With some performance pads and rotors, SS lines and better fluid, bigger M/C, it will stop even better then stock.
Old 09-20-2006, 11:23 PM   #8 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
If I'm not mistaken RSX-S A-Spec is only a body and suspention kit...
Old 09-20-2006, 11:26 PM   #9 (permalink)
Nope
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7977146776
Old 09-20-2006, 11:30 PM   #10 (permalink)
CaliGuy's Avatar
It looks like they are just slotted and x-drilled. From what I understand this does absolutely nothing...except look cool and wear out your pads faster....How come I feel a fight coming on?
Old 09-20-2006, 11:34 PM   #11 (permalink)
"They" say slotted wears out your pads faster, but it keeps the pad surface fresh. Crossdrilled can be a misnomer. Quality C/D are actually not drilled, but cast with the holes in them already. The cheaper ones are drilled and they can warp over time.
Like I mentioned above, some quality upgrades to the stock brake system will be more then good enough.
Old 09-20-2006, 11:46 PM   #12 (permalink)
+1. I only want a rotor upgrade for aesthetics. Everything else works just fine :)
Old 09-20-2006, 11:57 PM   #13 (permalink)
caveman74's Avatar
Kevin
You know I am gonna get some Brembo blanks. My first thing is I am gonna do is paint the outer edges grey, so they wont RUST. I am pleased with the stock brakes.
caveman74 is offline   Reply With Quote
Old 09-21-2006, 12:03 AM   #14 (permalink)
CaliGuy's Avatar
^^^Word on the rust proofing...it's so f'n annonying!
Old 09-21-2006, 12:13 AM   #15 (permalink)
Corpsman's Avatar
I think the ABS activates too quickly.
Corpsman is offline   Reply With Quote
Old 09-21-2006, 12:15 AM   #16 (permalink)
Also consider that the big-brake kits will add unsprung weight. Bigger rotors and calipers will weigh more then the smaller stock sized parts.
Old 09-21-2006, 12:29 AM   #17 (permalink)
Tuna Fiddle™
Dave
^^exactly and 1lb of unsprung weight is equal to like 1.4lbs of sprung weight. Oh well if you got the power to make up for it i guess its ok but IMO it is an aesthetic upgrade just like skittles said earlier
2006 Civic Body Kit (k&N design) GeorgiaBoy Inside and Out 23 04-24-2008 02:44 AM
What I learned about the HFP Aero Kit!!!!!! cornerstrike Inside and Out 26 03-22-2007 11:07 AM
What I learned about the HFP Aero Kit!!!!!! cornerstrike Inside and Out 9 09-05-2006 04:03 PM
Metra kit vs. OEM kit Airwolf I.C.E., Electrical, Security, & Navigation 10 08-23-2006 06:05 PM
Wildwood big brake kit group Buy.. anyone interested? boostedg35 Garage 42 07-16-2006 10:23 AM
