camber kit ? - 8th Generation Honda Civic Forum
Old 04-21-2009, 03:09 PM   #1 (permalink)
camber kit ?
so i bought spc camber kits off some local guy but i had ordered ingalls also and couldnt cancell the order so now i have both kits. they are both different. i know the ingalls go on the shock bolts but what about the spc? i test fitted them on the shock bolts but they look too long. whats better? and where do they go? thanks for the help
spoonlover is offline
Old 04-21-2009, 07:41 PM   #2 (permalink)
trickyazn's Avatar
uhhh the SPC should look identical to the bottom one that you have. Are you sure its for the right car?
Old 04-21-2009, 07:49 PM   #3 (permalink)
bought them off some guy w/ a two door. are the 2 and 4 door different. is the top spc for the rear kit? maybe?
spoonlover is offline   Reply With Quote
Old 04-21-2009, 07:54 PM   #4 (permalink)
trickyazn's Avatar
no. spc/ingalls look IDENTICAL in every single way. I think you got the wrong one.
Old 04-21-2009, 07:57 PM   #5 (permalink)
are they for the rears then?
Old 04-21-2009, 07:58 PM   #6 (permalink)
trickyazn's Avatar
no.. the rears either is a WHOLE ARM or a bracket. Like I said, you got the wrong one.
Old 04-21-2009, 08:00 PM   #7 (permalink)
just went on corsport they are for the rear
Old 04-21-2009, 08:02 PM   #8 (permalink)
trickyazn's Avatar
okay its a piece of it.. wheres the bracket?
if you didn't take a picture of the whole thing then how are we going to know what its for?
Old 04-21-2009, 08:06 PM   #9 (permalink)
i got the bracket and arm but the seller told me they were the front. he said he had front and rear. so i figuered it was the front but when i recieved the ingalls they didnt look right
Old 04-21-2009, 08:08 PM   #10 (permalink)
trickyazn's Avatar
next time do your research.
Old 04-21-2009, 08:12 PM   #11 (permalink)
problem solved
When To Use Camber Kits?/do I Need A Camber Kit? Highrev1 Suspension and Brakes 353 10-30-2011 05:56 PM
Too much negative camber? Front camber kit review aki Suspension and Brakes 11 06-20-2008 03:26 AM
