Buddy club N+ - Page 409 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Suspension and Brakes
Old 12-26-2012, 12:56 AM   #8161 (permalink)
dnorris89's Avatar
Don
Installing these is easy, front is literally 3 bolts in the strut tower and the 2 bolts holding on the knuckle, just be sure to unclip the abs sensor. Rear is a little harder because you have to pull the spring out from the control arm. Best bet is to have a friend press down on it and pull it out, just watch your fingers. Shock slides up into your trunk. It's pretty straight forward. There is a DIY for bc coils or something just look at that and search this thread for measurements, but do not use the settings from the first page. Goodluck and post some pics
Sent from my iPhone using AutoGuide.com App
dnorris89 is offline   Reply With Quote
Old 12-26-2012, 01:54 AM   #8162 (permalink)
LimeyJames's Avatar
James-R18 Crew Member #1691
awesome! cheers bro! any info on the fenders?
Unfortunately I wont be installing them until march. there is tones of snow everywhere here and its -32 right now haha, so I am going to order them march 1st.
I cant wait!!!
LimeyJames is online now   Reply With Quote
Old 12-26-2012, 02:51 AM   #8163 (permalink)
Cris_Fresh's Avatar
I'm on 18's with 225/40 tires and lowered about 1.5 in the rear. I don't rub at all so you won't have to worry about rubbing.
Cris_Fresh is offline   Reply With Quote
Old 12-26-2012, 03:19 PM   #8164 (permalink)
dnorris89's Avatar
Don
I cant wait!!!
Fender work all depends on how wide your tires are and what the offset is. My fenders are rolled and pulled in the front. I did them myself with a friends heat gun and fender roller. I had no experience but took my time and they came out great. People make it seem way worse than it is, honestly I wouldn't let that impact your decision.
Old 12-26-2012, 03:37 PM   #8165 (permalink)
LimeyJames's Avatar
sweet!
well I have been trying to decide about wheel spacers, when I drop it too, but the fender work does freak me out just a bit because I dont know anyone with the tools to do so. May end up having to buy a fender roller.
Old 12-26-2012, 03:40 PM   #8166 (permalink)
dnorris89's Avatar
Don
U can rent them for like 50 bucks online too. And you have to remember when you lower it naturally youll get more negative camber so the top of the wheels will be closer to the suspension and further from the fender.
Old 12-26-2012, 04:42 PM   #8167 (permalink)
AndCBRew's Avatar
Andrew
thinking of picking these up. subscribed
AndCBRew is offline   Reply With Quote
Old 12-26-2012, 05:08 PM   #8168 (permalink)
Cris_Fresh's Avatar
Once you get the rears adjusted to the desired ride height and correct settings. The ride is so comefortable. I'm loving them so far.
Old 12-26-2012, 10:40 PM   #8169 (permalink)
Dzavid
Originally Posted by Bruhnsun View Post
I really like the way your car looks. What size tires are you running, the look almost non-existent lol
thanks bro. I'm running 215/35/18 stretch
Dzavid08 is offline   Reply With Quote
Old 12-26-2012, 11:19 PM   #8170 (permalink)
jdmdanguan's Avatar
An
I got version 2, is lowering spec same as version 1. Trying do 1-2in drop. I know shocks shorter
jdmdanguan is offline   Reply With Quote
Old 12-27-2012, 12:01 AM   #8171 (permalink)
dnorris89's Avatar
Don
No the specs are different.. Someone said the specs are on page 246 for version 2 or something. Honestly I would just adjust the fronts to 80mm and raise or lower from there. I'm at 70 which tucks a little front tire if that helps, front are super easy to adjust
Old 12-27-2012, 02:13 AM   #8172 (permalink)
Cris_Fresh's Avatar
The specs are different. I have the v2's and when I tried using the specs off the first page I got a serious case of the clunking noise. But now since I used the specs on page 246, all of that is gone and my ride is smoother than ever.
Old 12-27-2012, 02:19 AM   #8173 (permalink)
BH_FA5's Avatar
Brenda
nice post!
BH_FA5 is offline   Reply With Quote
Old 01-02-2013, 06:58 AM   #8174 (permalink)
Under Moderation
Cant wait to put my coils in
DOHC-iVTEC is offline   Reply With Quote
Old 01-08-2013, 03:22 AM   #8175 (permalink)
mrxant's Avatar
my rear squeaks over every single little bump, sounds like there are mice in my trunk. also, over hard bumps i hear a thump in the back also. could it be the rubber bushings on the rear shock? my preload for the shock is at 190mm and 0mm on perch with both rings.
mrxant is offline   Reply With Quote
Old 01-11-2013, 07:12 PM   #8176 (permalink)
Jayman2143's Avatar
Jay
Mine has started to do that also. Kinda sounds like the back left one is bouncing up and down in the trunk or something. Havent had a chance to diagnose the problem yet.
Jayman2143 is offline   Reply With Quote
Old 01-12-2013, 07:27 AM   #8177 (permalink)
JDMlove's Avatar
Colton
It might be the bushings that are on the bottom of the strut going bad
Sent from my iPhone using AutoGuide.com Free App
JDMlove is offline   Reply With Quote
Old 01-13-2013, 04:35 PM   #8178 (permalink)
civic_si_lover's Avatar
Brandon
sub'd picking a set of these up sometime before spring
civic_si_lover is offline   Reply With Quote
Old 01-13-2013, 06:18 PM   #8179 (permalink)
Jayman2143's Avatar
Jay
Looked into this a little more. Unbolted everything today and inspected all the bushings and what not. Couldn't find anything noticeable that would be making the squeaking noises. I did see that my camber arm had a little bit of wiggle room around the bolt so I tightened that one nice and strong. Then tightened everything up and cleaned it all since I live in NJ and everything was covered in road salt. Took it for a test drive and I didn't hear the noise anymore. So I'm thinking something may have been a little loose such as the camber arm or something. I guess we will see if the noise returns.
Old 01-13-2013, 06:32 PM   #8180 (permalink)
torque specs baby
BlownNHBPSI is offline   Reply With Quote
Buddy Club N+ Greatwhite Suspension and Brakes 9 12-25-2011 05:45 PM
buddy club n+ azncivicsi Suspension and Brakes 8 11-09-2008 04:10 AM
Buddy Club N+ help Lanki Suspension and Brakes 1 09-16-2008 07:14 PM
my buddy club azncivicsi Inside and Out 4 02-09-2008 05:06 PM
Buddy Club stuff....??? muxtang67 Bolt-Ons And All-Motor 9 10-05-2006 04:57 PM
