Buddy club N+ - Page 10 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Suspension and Brakes
Old 04-10-2009, 12:43 PM   #181 (permalink)
trans9mp's Avatar
Clint Shifflett
now this is my right side... which is the side im having problems from... notice the difference... i think this could be my issue...
trans9mp is offline   Reply With Quote
Old 04-10-2009, 12:45 PM   #182 (permalink)
dvs08FA5's Avatar
Chris
Go through every bolt and retighten them, if you haven't do so all ready.
dvs08FA5 is offline   Reply With Quote
Old 04-10-2009, 12:48 PM   #183 (permalink)
trans9mp's Avatar
Clint Shifflett
done the best i can with what little tools i have available too me... half the bolts i cant even loosen... so im pretty sure they are tight...
Old 04-10-2009, 12:54 PM   #184 (permalink)
dvs08FA5's Avatar
Chris
Mine made a banging kind of noise when going over bumps when I first installed them. It ended up being the top ones, the ones in your pics. Try and get those as tight as possible. If everything is installed right and tight there should be no noises. When I get a chance i'll look at my top washer. GL
Old 04-10-2009, 01:00 PM   #185 (permalink)
trans9mp's Avatar
Clint Shifflett
yeah im going to try... someone said something about using the stock bolts because you can get those tighter... which is what i attempted to do today but i accomplished nothing but damn near stripping one of them... i couldnt get the thing off... it just kept twisting the rubber gasket underneath as well as the entire damper setting bolt the nuts tighten onto... so i gave up since i didnt wanna break it... im gonna take it back to the shop that did mine and give them the stock bolts and tell them to replace and try to get as tight as possible... when i go over things like speedbumps i can def near a noise like something on the top isnt tight... i just dont wanna break it trying to get it tighter you know what i mean?
i cant imagine things not being installed correctly tho... suspension is suspension... not really rocket science... and these were professionals that installed mine, ppl who do this kind of work daily... so i dont know... im just gonna get it back in there next week... i wanna re-adjust the rear anyhow...
Old 04-10-2009, 01:05 PM   #186 (permalink)
trans9mp's Avatar
Clint Shifflett
which way is that washer supposed to face tho? because on the left side they have the washer facing up, and on the right the washer is facing down... and obvisiously im having issues with the right side... ive tried to loosen that bolt so i can get the washer facing up and i cant get it to loosen... any ideas?
Old 04-10-2009, 01:06 PM   #187 (permalink)
sm2s's Avatar
teddy
i can see it, but the cylinder they gave me is between the washer and the nut, different from yours. you have yours under the rubber?
sm2s is offline   Reply With Quote
Old 04-10-2009, 01:07 PM   #188 (permalink)
trans9mp's Avatar
Clint Shifflett
im assuming thats where its at bro... because its not on top, and its def not underneath since i was just under there messing around no more than 20 mins ago... unless its just not on there with my car... but they gave me everything back after they were done... and those peices are def not there, but the stock ones are... so i think they go thru the middle of the gasket
Old 04-10-2009, 01:08 PM   #189 (permalink)
sm2s's Avatar
teddy
the stock washer is how it was on the left.
Old 04-10-2009, 01:11 PM   #190 (permalink)
trans9mp's Avatar
Clint Shifflett
yeah so i def need to get that one on the right switched... but i cant get the bolt to loosen... i tried and tried... it turns... but so does the threaded section and the gasket... i dont wanna snap it off or something trying to loosen it...
Old 04-10-2009, 01:18 PM   #191 (permalink)
trans9mp's Avatar
Clint Shifflett
can anyone post up some pics of a 100% accurate install that has no banging or noises? both top perches and underneath? so i can compare with mine...
Old 04-10-2009, 01:50 PM   #192 (permalink)
sm2s's Avatar
teddy
this is happening to me too, when i try to tighten it.
Old 04-10-2009, 02:48 PM   #193 (permalink)
i see the pics now. my washers on top both have the curled edges facing up. I still get the noise and clunking. There has to be a solution to this. I'm about to go back out right now and adjust it one more time.
Also, the long cylinder peice you guys are referring to goes in from the bottom and sits inside the rubber bushings where you bolt the shock into the trunk. hope that clears that up for you.
westonk900 is offline   Reply With Quote
Old 04-10-2009, 02:56 PM   #194 (permalink)
sm2s's Avatar
teddy
yes it does just finished reinstalling the rears will take pictures later
Old 04-10-2009, 03:04 PM   #195 (permalink)
sm2s, do you have the knocking sound in the right rear as well?
Old 04-10-2009, 03:13 PM   #196 (permalink)
trans9mp's Avatar
Clint Shifflett
yeah someone give me some insight... haha... my cyclinder things are both inside the rubber gasket or bushings if thats what you wanna call it... the only thing different between my right and left is how that washer is placed... left facing up and right facing down...
sm2s - let me know how it goes after the reinstall? trying to get some direction before i take it back into the shop...
Old 04-10-2009, 03:21 PM   #197 (permalink)
also, on the rear shocks, are you supposed to measure from the top of the threads or from the top of the shock housing to get the correct measurement???
Old 04-10-2009, 03:25 PM   #198 (permalink)
trans9mp's Avatar
Clint Shifflett
west... are you a member or miraclegarage.com? they have all the info there on how to adjust and set... if you are, log in and go to this URL... it has how to measure and adjust...
on the rear, you measure from the silver washer on top of the threads, to the locking bolt...
Miracle Garage Forum - Index
Old 04-10-2009, 03:44 PM   #199 (permalink)
yes i am a member on there now. i was just on there trying to get some feedback, lol! anyways that is how i have been measuring. i just wanted to make sure i was doing it correctly. what about on the actual spring perch? do you measure from the base of the perch to the top of the spring or to the top of the second locking perch that butts up to the perch that the spring sits against?
sorry that kinda sounds confusing.
Old 04-10-2009, 03:49 PM   #200 (permalink)
trans9mp's Avatar
Clint Shifflett
the only place you need to measure is whats listed on miraclegarage.com; the only thing i can think of is something somewhere is loose... im baffled... hopefully i get some kind of feedback from miracle garage here soon...
Buddy Club N+ Greatwhite Suspension and Brakes 9 12-25-2011 05:45 PM
buddy club n+ azncivicsi Suspension and Brakes 8 11-09-2008 04:10 AM
Buddy Club N+ help Lanki Suspension and Brakes 1 09-16-2008 07:14 PM
my buddy club azncivicsi Inside and Out 4 02-09-2008 05:06 PM
Buddy Club stuff....??? muxtang67 Bolt-Ons And All-Motor 9 10-05-2006 04:57 PM
