Old 09-07-2006, 02:43 PM   #1 (permalink)
strut bars & sway bars
yo can someone explain to me the difference ???????what benefits do they provide ....would the 06 si benefit from these? do you combine strut an sway or just stick to one or the other ......an who is selling good strut/sway bars .....umh yeah thanks =) sorry i lack the strut an sway knowledge
soymilk is offline
Old 11-28-2006, 04:19 PM   #2 (permalink)
James
Suspension 101.....
The strut tower brace will help reduce any flex in your chassis when you enter corners. The front subframe is already pretty rigid, but some members report that they experience some improvement from them.
Sway bars transfer weight from the outside wheel to the inside wheel when you are turning. This helps eliminate body roll. I have only seen 1 roll bar and it is from Progress suspension, I have seen 1 on eibach's website also, but not on any retailer's sites. The one from Progress is a 22mm bar which is the same size as your stock si's bar. I have a lx so someone correct me if I am wrong but I believe that the rear sway bar on the si is hollow. I am not sure if the progress bar is hollow or solid. I havnt heard any reviews on the progress bar. However if the progress bar is hollow then there is really no point to change it. Anyways a stiffer rear sway bar will decrease understeer, a larger front will increase understeer.
Both parts are available at: www.corsportusa.com
Hope I was able to help a little.
slimjim8481 is offline
Old 11-28-2006, 04:25 PM   #3 (permalink)
faptastic... pew pew pew
rippars's Avatar
Ryan
stock si rear sway is 17mm and the progress rear sway is 22mm.
plenty of reviews on the fourms just need to do a search...
Ordered a Progress Technology rear sway bar
FEEDBACKS on PROGRESS SWAY
Progress swaybar
as for front sway bars and braces havent seen as many people with them compared to the rear sway, but i have seen one or two times the tanabe brace didnt help as much as the rear sway did.
06 asm si
Teh Ryan's are up to it again: I Failed In Mah Pants, Burrito Bowl Duece Meet Thread
Originally Posted by firmhonda
2fast is a chick?!? WTF?
rippars is offline
Old 03-13-2007, 11:26 AM   #4 (permalink)
I did just the rear SI sway bar, then the front SI sway bar also and put in a set of used SI struts, but went back to SI front and rear bars, which seemed to be the best ride and handling for daily driving...
timmay is offline
sway bars soymilk Suspension and Brakes 4 11-07-2006 11:54 PM
Tanabe sway bars fhound258 CorSport 9 09-11-2006 10:54 AM
Kinda on topic: Will 03+ Element sway bars be directly compatible on the 03+ CRV? honda93 Suspension and Brakes 3 09-04-2006 12:52 AM
Progress sway bars blackfg2 CorSport 5 07-25-2006 01:16 PM
