Old 09-07-2006, 08:26 PM   #21 (permalink)
Moderator
sickyute's Avatar
Marvie
i have this upgrade also..i've yet to scrape on anything.
the difference is minimal
it should be note worthy that i also have the progress rear bar and that was on first.
Shift when it blinks!
Old 09-07-2006, 08:31 PM   #22 (permalink)
kdb
kdb's Avatar
I just ordered both of these parts. Hopefully I can get them and install next week. Will these make a big difference with a non lowered stock si? HFP suspension is next.
kdb is offline   Reply With Quote
Old 09-08-2006, 03:09 AM   #23 (permalink)
larryd's Avatar
I didn't even think about how it sits under the car. I'll keep that in mind when/if I go over speed bumps.
larryd is offline   Reply With Quote
Old 09-08-2006, 03:14 AM   #24 (permalink)
eugenekim.net's Avatar
captain obvious
ordered mine earlier today
Old 09-08-2006, 02:26 PM   #25 (permalink)
reaper702's Avatar
How much is the car lowered for the ppl that scrape on speedbumps? I'm looking to add these 2 next and a couple months add the HFP suspension which is .9 inches so will that have clearance issues?
reaper702 is offline   Reply With Quote
Old 09-08-2006, 04:17 PM   #26 (permalink)
Moderator
sickyute's Avatar
Marvie
well...i'm very low on tein super streets...like a finger gap between tire and fender....barely
i've yet to hit anything.
Old 09-08-2006, 04:34 PM   #27 (permalink)
reaper702's Avatar
with that said looks like i will be getting progress rear sway, tanabe sustec then hfp suspension :)
Old 09-08-2006, 11:51 PM   #28 (permalink)
honda93's Avatar
I agree with sickyute... That piece mounts to one of the strongest areas of the unibody. The new FG chassis is much stiffer than people are realizing. In almost a year of autocrossing the new LX Coupe, I can honestly say that I feel no shudder or shake anywhere while on the road or on the autocross course.
Now, on the 1993 Civic autocross beast I had, yes, braces were a necessity, especially after I started running custom rate Konis and really high spring rates along with gigantic sway bars.
In short... Money spent on one of these Tanabe pieces should be considered a cosmetic upgrade, not a performance one.
Anthony "Mario" Crea
NNJR-SCCA
Old 09-09-2006, 01:06 AM   #29 (permalink)
larryd's Avatar
Ok then, atleast is pretty
Old 09-10-2006, 04:40 PM   #30 (permalink)
RWatters's Avatar
NNJR-SCCA
I 100% agree.
I had the Si on jackstands a few weeks ago and got underneath the car to swap out exhaust systems. When I I looked at the jackstands while moving around I noticed that 3 were in place firmly and one actually had half an inch of air between the stand and the body. That's how stiff this chassis is. I have NEVER put a car in the air like that before and have light between the stand and the chassis. Needless to say I had a pretty big grin after seeing that even with all that air in there the chassis didn't twist/move at all.
RWatters is offline   Reply With Quote
Old 10-31-2006, 10:14 AM   #31 (permalink)
8thcivic Sponsor
CorSport's Avatar
The fg and the ep are both extremely stiff chassis's - but folks these bars really do something, you will feel it, I know I could on the ep3.
Anyway, support a sponsor, get yours at CorSport: Tanabe Sustec 4-Point Under Braces <---- we have 2 in stock on the shelf currently, while Tanabe themselves are on backorder until January.
Thanks for looking,
Tai
CorSPort
www.CorSportUSA.com
Performance Aftermarket Parts
Honda Performance, Defined.
CorSport is online now   Reply With Quote
Old 10-31-2006, 05:21 PM   #32 (permalink)
Garrison's Avatar
Garrison
Maybe after my sway bars have been replaced.
Garrison is offline   Reply With Quote
Old 11-04-2006, 03:57 PM   #33 (permalink)
blaznhot_23's Avatar
MS Motorsports kicks ass!!!
anyone have any problems with scraping with the sustec brace...i assuming on really low cars it would present a problem...but what about the hfp kit??? I heard that the cusco underbrace is my tucked up and away than this one??? can someone confirm???
blaznhot_23 is offline   Reply With Quote
Old 11-05-2006, 02:00 PM   #34 (permalink)
RWatters's Avatar
Mine scrapes on certain speedbumps. Most of them I can avoid scraping by taking it at an angle and going very slowly over. Some I can't avoid period. You have to be careful with road debri as some of it will hit the brace. I've hit quite a few things and scraped quite a few times and all the brace has to show for it is a couple of scars. This thing is TOUGH and has taken the abuse I've thrown at it perfectly so far. No bends, no breaks, no cracks, no anything.
The Cusco brace looks to have a lot more clearance under the car, yes.
Old 11-05-2006, 03:50 PM   #35 (permalink)
how low is your car??? mine is at stock height right now but i'm going to do the hfp drop on it??? I thought about the cusco bar but you have to bend some exhaust hangers to make it fit i think
Old 11-05-2006, 05:25 PM   #36 (permalink)
RWatters's Avatar
I have the Tein S-Tech's which lower the car quite a bit over stock. With stock or the HFP suspension I'd say you'll be perfectly fine. I don't think it'll lower the car enough for you to have many clearance problems.
Old 11-05-2006, 05:36 PM   #37 (permalink)
how much more clearence can you get by going with the cusco unit over the sustec ??? i would assume it is negligible
Old 11-05-2006, 06:21 PM   #38 (permalink)
RWatters's Avatar
Maybe an inch, 2 inches at the max?
Old 11-05-2006, 07:26 PM   #39 (permalink)
two inches is a lot...especially if you are lowered. i'm going to have to look into the cusco unit before i make a purchase....any pics of the cusoc bar and where to go for it???
Old 11-06-2006, 11:29 AM   #40 (permalink)
8thcivic Sponsor
CorSport's Avatar
^Isnt that an upper bar for the ex/dx/lx only?
The sustec is maybe 2 thick at the most -- in most sections way thinner then that --- anyway, I dont see how any bar would be 2" more clearance then the sustec brace as thats the thickness of the brace at its largest mounting point.
Tai
CorSPort
www.CorSportUSA.com
Tanabe Medallion Concept G axleback installed on EX Coupe stevieray Bolt-Ons And All-Motor 27 10-08-2007 02:42 AM
TANABE SUSTEC FRONT LOWER ARM BAR CIVIC COUPE 06+ mishima8 Suspension and Brakes 6 12-15-2006 12:03 PM
Email from Tanabe to Me about Exhaust (R18) 06Ex Garage 3 09-10-2006 12:01 PM
PIC REQUEST: Tanabe Exhaust BLU BY U Bolt-Ons And All-Motor 6 06-04-2006 12:49 AM
Sustec Underbrace FujiBlueSi Suspension and Brakes 1 05-17-2006 01:29 PM
