Q: Eibach Pro-kit???
I recently purchased these suckers for my 06 civic dx
and have a few questions regarding them, so any help is appreciated!! a. After removing the front struts from the car can i just stand on the spring while its flat on the ground, then removing the top bolt to get the spring off? because i seen a tutorial here that says you can but for most Hondas? b. Camber - With the Pro-kit is a 1" drop, Will I need a camber kit for this application?? c. I seen another tutorial for Tein coils for which he had to remove the plastic piece from the car (under the hood by front windshield), What exactly was this intended for? d. I own 18" rims on 40 series tires, am i gonna take em out by rubbing the rear quarters? If there are any other concerns i should know off hand before attempting this mod please let me know? Thanks! |
#2 (permalink) | |
63.7% Bostonian.
I just bought the same springs...
I am getting a camber kit; it may not be totally necessary, but given the cost of 40-series tires, and also for the sake of traction, I'd keep your camber exactly where the service manual says it should be. I also have 18" 40-series tires... I have asked several other people, and rubbing is mostly dependent on your offset. Anything above +40mm and you should be alright... less, you may have problems. I'm going to add a question now :) I'm at work right now, so I can't get to it, but the instructions in the box say something about cutting the bump stop. The Tein DIY on this site doesn't mention it at all... is this an Eibach-specific step or is it not necessary? Thanks! J
. Si away for the winter ![]() Winter projects: - LED taillights (following in Nomar's footsteps) - two-tone seats - misc electrical stuff - audio overhaul - random powdercoating Quote:
#4 (permalink) | ||
63.7% Bostonian.
#6 (permalink) | |
63.7% Bostonian.
Cool. I always prefer to make as few permanent changes as possible, if for some bizzare reason I have to change things back to stock. I'm going to order camber parts as soon as I get paid (Thursday
) so I should have the kit going on in a few weeks. If you get yours on before me, let me know how it went!J
i was gonna do this today with my good buddie si_civic
but he was green today....bah! besides i got called into work and that screwed me up, but im thinking first thing tommorow renting a spring compressor and doing it then. ill post pics when i get it installed. |
#8 (permalink) | |
| 2006 Civic Body Kit (k&N design) | GeorgiaBoy | Inside and Out | 23 | 04-24-2008 02:44 AM |
| Metra kit vs. OEM kit | Airwolf | I.C.E., Electrical, Security, & Navigation | 10 | 08-23-2006 06:05 PM |
| Eibach Pro Kit Install Help in Phoenix | Tigger1 | Suspension and Brakes | 3 | 06-12-2006 12:20 PM |
| Eibach pro kit pictures | pigman | Garage | 11 | 05-13-2006 11:54 AM |
