Old 09-04-2006, 05:10 PM   #1 (permalink)
Lucky13's Avatar
LOwering the Si
Now I have been searching and reading for a whilte today on 8th Civic...but can't come up with an answer....Do you need a camber kit if you drop the Si with any Springs...As much info you can give is great luv ya guys..your Si /8th Vic Bro......
Lucky13 is offline   Reply With Quote
Old 09-04-2006, 06:03 PM   #2 (permalink)
Si-aficionado's Avatar
No camber kit needed when a car is droped, but the inside part of your tires will wear out a lot faster from the negative camber..so you decide camber kit or new tires every 6 months..
Si-aficionado is offline   Reply With Quote
Old 09-04-2006, 06:10 PM   #3 (permalink)
06CivEXJon's Avatar
Jon
What about with eibach sportlines 1.4''? you need camber kit with it? if so where do you buy it at?
Old 09-04-2006, 06:18 PM   #4 (permalink)
Everytime a car is lowered even if it's only an inch, you are changing its factory specs and alignment
As for Sportlines, I have no idea, try google
Old 09-04-2006, 08:38 PM   #5 (permalink)
Lucky13's Avatar
Ok so tell me PLEASE Really really quick answer this ...so if the dealer put the HFP Springs on they are instlling a camber kit ALSO??????
Old 09-04-2006, 08:43 PM   #6 (permalink)
06blaksi's Avatar
No they are not...camber kits are only required for 1 inch or more. The HFP suspension is .8 inch
Old 09-04-2006, 09:59 PM   #7 (permalink)
edrhee83's Avatar
Ed Rhee
As for Sportsline, I suggest the camber kit. I rather buy camber kit for $250 and not changing tires for $200 every 5-6 months.
edrhee83 is offline   Reply With Quote
People with lowering springs... How are you stock struts holding up? DumbasSi Suspension and Brakes 41 09-02-2007 10:43 AM
General feedback on lowering... OHSiGuy Suspension and Brakes 21 08-08-2006 12:34 AM
Lowering + Winter Season = ? Yodums Suspension and Brakes 7 07-28-2006 05:06 PM
Lowering questions. Marin Suspension and Brakes 9 07-01-2006 12:20 AM
2006 Civic EX/LX Lowering Springs Survey.. unplugged Suspension and Brakes 19 03-16-2006 12:54 AM
