Old 09-03-2006, 10:18 PM   #1 (permalink)
knock noise after install tein?
i just install a tein lowering spring,and spc camber kit
but there is a little bit noise when i turn left or right specialy when i drive kinda slow, i think is came from front
is it anybody know what kind a noise is it?
ronjancivicsi is offline   Reply With Quote
Old 09-04-2006, 01:35 AM   #2 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Did you cut the bumpstop?
Old 09-04-2006, 01:39 AM   #3 (permalink)
faptasic... pew pew pew
rippars's Avatar
Ryan
did you get an alignment done yet?
< click and donate nao
Originally Posted by jasonandre
Who wants to wash my car?
Originally Posted by dentrecords
sure. where would i find it?
Old 09-04-2006, 01:51 AM   #4 (permalink)
Hybrid_Customs's Avatar
David Oakley
How long has it been since the install?
Hybrid_Customs is offline   Reply With Quote
Old 09-04-2006, 04:52 PM   #5 (permalink)
i,m not sure
Old 09-04-2006, 04:53 PM   #6 (permalink)
yes 2 times ,couse afterthat i,m install a spc camber kit
Old 09-04-2006, 04:53 PM   #7 (permalink)
3 days
Old 09-04-2006, 05:16 PM   #8 (permalink)
rippars's Avatar
Ryan
hmm... where is the noise coming from? when i got my progress rear sway and hfp suspension on i had the same problem while backing up and turning at low speeds. took to a friends shop where they went over the install, alignment, and added more grease to the bushings on the swaybar did the trick for a while and the noise came back. most of the nosie was coming from the sway bar but i think some came for the springs in the rear til they got settled in.
Old 09-08-2006, 01:00 PM   #9 (permalink)
kenchan's Avatar
if your camber rods have heim joints (metal ball joints) then
its not unusual to have knocking noises while driving slow.
on my other car and previous modded cars i owned, they all
made some noise at low speeds coming from the heim joints
(pillow mounts, endlinks, camber rods, etc). some made more
noise than others, some made zero noise.
Spinning noise gradually increasing as RPM goes up joonoo Mechanical Problems & Technical Chat 0 09-03-2006 02:54 AM
TEIN s-tech install pics!! (56k die) aznchzexr Suspension and Brakes 26 07-23-2006 05:57 AM
Just finsish install ..Tein SS Black_civic_Si Suspension and Brakes 8 06-19-2006 02:58 AM
Tein SS coilovers sickyute Suspension and Brakes 19 04-19-2006 11:11 AM
Tein Basic vs. Tein SS? duy2006si Suspension and Brakes 2 04-18-2006 01:46 AM
