Anybody have HFP suspension and a Progress rear sway?
I just ordered my HFP kit this morning and am debating if I should put the progress bar on. I know rear sways help a ton, I had one on my Legacy GT, but is it overkill on the si?
Also how will the stock endlinks hold up with a thicker sway bar? |
faptasic... pew pew pew
had both on my ex and i loved it! im sure the endlinks could be used with the sway bar since my stock endlinks held up with the progress sway bar and the ex sway bar is smaller than the stock si sway bar. in the end if i dont go with tein ss i'll be going and getting the hfp suspension again. really miss the setup i had in the ex since i could feel the difference in turns in the si without it.
Sensible member
I've got both! Handles awesomely and the ride is barely affected.
I emailed Progress about the endlinks and they said the stock ones are fine. I haven't broken any yet. I've done some spirited driving and will do quite a bit more next weekend. I'll let you know if I break anything.
Supreme Pizza!
For our application, no. It appears that Progress gave the endlinks an OK as far as strength and rigidity. If you wanted to be sure, get the RSX endlinks from Hotchkis. But, personally, unless you plan on tracking it, if Progress says it's cool, you probably have little risk of damage for everyday driving.
#9 (permalink) | |
So with the hotchkis endlinks (rsx 05) fit perfect with the progress swaybar and in the car? no mods needed? |
#12 (permalink) |
Are these any good? http://www.corsportusa.com/store/cat...oducts_id=1108
#13 (permalink) | |
They may work but they are harsh and noisy. I had a set and I replaced them with the Hotchkis. |
#15 (permalink) |
my question regarding sway bars here is:
i have the DX-G model which to my knowledge has no swaybar in the rear? So is there still a place to install one if its not there and i would need what? - Antiroll bar - Bushings - Mounts & bolts - Endlinks Cuz im going to install the Si sways up front for sure but what do you guys reccomend for the rear as i drive hard in corners (also have Eibach Pro kit installed already)/ thanks! |
#19 (permalink) | |
renick motorsports. I think it's renickmotorsports.com http://www.renickmotorsports.com/oscommerce/catalog/ Not sure if they ship to PR or not. |
#20 (permalink) | |
| Si Rear Sway Bar on CSX | iluvmycsx | Suspension | 23 | 11-13-2008 09:13 AM |
| Si Front & Rear Sways on an EX Sedan | iVTEC | Suspension and Brakes | 231 | 09-15-2008 05:21 PM |
| noise from rear... hfp suspension and progress rear sway bar | rippars | Mechanical Problems & Technical Chat | 8 | 07-01-2008 09:42 PM |
| Ordered a Progress Technology rear sway bar | Cookstar | Suspension and Brakes | 22 | 06-16-2006 03:08 AM |
