Si Springs On R18? DIY Request - 8th Generation Honda Civic Forum
Old 01-27-2009, 05:24 AM   #1 (permalink)
raybyduhbay's Avatar
Ray
Question Si Springs On R18? DIY Request
I tried searching for 2 days and still no result as if any r18 members put si springs on thier ride.
same ride height? better handling?
how many hours to change all 4 springs?
I also need to know how to change the springs on the r18 as it looks different from the SI DIY on this forum. front and back plz
raybyduhbay is offline
Old 01-27-2009, 05:57 AM   #2 (permalink)
Quail Man!
GETxERxDONE's Avatar
Nick
it will be the same as an SI. if it was different, the si suspension wouildnt fit..
the ride height will be a tad bit higher but it will handle better and ride will be stiffer
GETxERxDONE is offline   Reply With Quote
Old 01-27-2009, 05:59 AM   #3 (permalink)
Ray
how much is a tad higher? do u have this set up?
raybyduhbay is offline   Reply With Quote
Old 01-27-2009, 06:02 AM   #4 (permalink)
Quail Man!
Nick
a tad is like .2 or so inches higher. no i dont have the setup. i just read, alot
Old 01-27-2009, 06:03 AM   #5 (permalink)
Ray
is that .2 for all around?
man i seriously cannot find anyone that has this setup to shine some light on this subject
Old 01-27-2009, 06:12 AM   #6 (permalink)
xheartcore_boyx's Avatar
3bood aka Addy aka Bo dawood
Get hfp suspension, think collegehills honda got a sale on these..
installed mine before couple days, car drives MUCH better even though the tires suck and i am rolling on steelies...
xheartcore_boyx is offline   Reply With Quote
Old 01-27-2009, 06:15 AM   #7 (permalink)
Ray
i would except im a broke college student and an 8th member here said they didnt mind throwing their si springs my way since he upgraded his
Old 01-27-2009, 06:16 AM   #8 (permalink)
hmm that's a good reason then, some guys with r18s installed the Si suspension and rear bar and they were impressed, just search a bet.
Old 02-06-2012, 02:19 PM   #9 (permalink)
xteabaggz's Avatar
D Tea
my friend did an install on his FA while i watched... if youre just replacing the springs, then you would need a spring compressor (very simple tool) that makes the job a lot safer. once the stock spring is compressed, i believe you will need a hex tool and a wrench to remove the top cap. the spring slides off, and then you replace it with the si spring. now you will need to un-compress the stock spring that has been removed, and use the tool to compress the si spring so you can put the cover back on.
repeat that for all four suspensions. as for installing it back on the vehicle, if youve taken it off, then its the same way putting it back in. to access the front two, you will have to remove the plastics that are below the windshield wipers.
edit: oops i apologize for reviving a dead thread
xteabaggz is offline   Reply With Quote
Request a DIY Buddy5791 Do It Yourself Articles 7 11-13-2008 01:32 PM
Request a DIY Buddy5791 Do It Yourself Articles 5 10-30-2008 02:28 PM
DIY request : Trunk Swap junkimchi Inside and Out 9 01-23-2008 11:54 AM
DIY Hacksaw Request eXe Mechanical Problems & Technical Chat 12 11-05-2007 03:52 PM
DIY request: Hole fix ElkLodgeEzra Do It Yourself Articles 5 02-27-2007 04:05 PM
