Rear clunk noise after prokit spring install - 8th Generation Honda Civic Forum
Old 12-27-2008, 01:36 AM   #1 (permalink)
So yeah, i just installed eibach pro kit springs, and after 50 miles or so, they now make an insanely annoying metal on metal tap/clunk noise when doing city driving. No noise at all on the freeway. Its only coming from the rears, doesn't look like the rear even has bumpstops so don't think its that.
I pulled the rear wheel off again today to look around and everything is put together correctly. All I can think of is the spring must be bouncing up and down too much on since it is shorter than the stock one. I didn't forget to put the rubber pieces back on the top and bottom of the spring either.
Anyone with similar symptoms know how to solve this one? Its extremely annoying, more than just a creek here or there.
THanks
dskater411 is offline
Old 12-27-2008, 01:51 AM   #2 (permalink)
Zeuceone's Avatar
The top rubber piece is necessary.
Old 12-27-2008, 03:13 AM   #3 (permalink)
Hieu
did u installed it upside down? Post a pic.
par72 is offline   Reply With Quote
Old 12-27-2008, 11:14 PM   #4 (permalink)
I have Zeel function T coilovers on my EVO X, and for the first few weeks they clunked and banged over the slightest pot-hole. Now they barely make a peep.
You should try to give it some break in time, although I've never heard of people having noise problems with just springs.
EvolvedX is offline   Reply With Quote
Old 12-28-2008, 03:45 AM   #5 (permalink)
As mentioned in my first post:
Spring is installed the right direction
dskater411 is offline   Reply With Quote
Old 12-28-2008, 03:47 AM   #6 (permalink)
Yeah my friends integra had coilovers that creeked all the time, this just sounds soo much worse, a metal on metal clunk. Ill give it some time and see if it gets better though.
If it doesnt, ill try removing the struts, cutting the rear bump stops, and installing those new little metal sleves that eibach provided.
People in the DIY spring install thread said these werent necesary but maybe it would help.
Old 12-28-2008, 04:04 AM   #7 (permalink)
Zeuceone's Avatar
I miss read the OP.
It sounds like you did everything correctly but something is not right. Can you go over exactly what you did? Or provide pics? Some people do get like a creaking noise from the springs but nothing like metal clunking.
Old 12-28-2008, 12:40 PM   #8 (permalink)
Xtreme Thunder's Avatar
Joey
The rear has a bump stop, it is inside the strut housing itself.
Xtreme Thunder is offline   Reply With Quote
Old 12-28-2008, 03:36 PM   #9 (permalink)
2000civic's Avatar
Robert
Pics would help
2000civic is offline   Reply With Quote
Old 12-28-2008, 03:44 PM   #10 (permalink)
Ruthless909's Avatar
Ls1 JeRk
Ruthless909 is offline   Reply With Quote
Old 01-02-2009, 06:57 AM   #11 (permalink)
trickyazn's Avatar
I have the same issue with my prokit.
Old 01-02-2009, 07:00 AM   #12 (permalink)
Zeuceone's Avatar
it might be that the exhasut pipe is hitting.
Old 01-02-2009, 07:02 AM   #13 (permalink)
trickyazn's Avatar
its insanely loud.. any mild bump on the freeway and i'd hear (clunk). I'm going to check the bolts tomorrow to see if any bolts came loose.
Old 01-03-2009, 10:00 AM   #14 (permalink)
bc8
bc8's Avatar
might be the rubber not in place causing the springs to hit the metal
Had that problem in the first week which I noticed especially through potholes and uphills with constant metal clunking on my skunk2.
The install was done properly by the mechanic
bc8 is offline   Reply With Quote
Old 01-05-2009, 01:29 PM   #15 (permalink)
VanSin23's Avatar
Van (08 ASMFA5)
mine done the same thing and I realized that my left rear sway bar link was not all the way tight.
VanSin23 is offline   Reply With Quote
Old 01-05-2009, 01:51 PM   #16 (permalink)
michinsi's Avatar
McTomalds
Mine seems fine....haven't heard any noise at all. Post up what the problem is once you find out the problem!
michinsi is offline   Reply With Quote
Old 01-05-2009, 07:32 PM   #17 (permalink)
well the noise seems to have gone away for now. Its been a few days since ive heard anything, so maybe the springs just took a while to settle, either way, if the noise comes back ill report but so far looking good!
Old 01-05-2009, 10:50 PM   #18 (permalink)
dorkiedoode's Avatar
Kevyn
im hearing the spring noise too but this is on HFP. it only have once or twice a day, early in the morning, and leaving work. everything else is normal. i hoping it's the spring settling in. im going to go out and torque the front. the noise is not loud either.
dorkiedoode is online now   Reply With Quote
Old 01-05-2009, 10:52 PM   #19 (permalink)
lowerlevel's Avatar
dave
same here, after 10k miles my shocks are very tired in the rear as well lol
well kinda same problem i herd a clunk maybe once or twice only when going over big bumps. but its gettin alittle bouncy after 10k
lowerlevel is offline   Reply With Quote
Old 01-05-2009, 10:57 PM   #20 (permalink)
Kevyn
After market shock guys. don't be cheap!
Sedan, clunk noise from right front ToBeHuman Mechanical Problems & Technical Chat 199 05-23-2011 01:20 AM
Rear Strut/Spring Popping Noise w/ Sportlines - What is it? tarh33l10 Suspension and Brakes 29 03-02-2009 05:26 PM
Front Spring Install / Noise problem found unplugged Suspension and Brakes 0 04-06-2007 04:34 PM
noise from rear neuspeed race spring visconti Suspension and Brakes 2 02-14-2007 09:15 AM
