Ryan
I ran the Civic LX front sway on my last Si and the grip going out of corners improved quite a bit. There was a little more body roll (obviously) but corner-exit understeer was dropped.
Luis
I'm not autocrossing or anything right now. Do you think it is okay to have just a stock SI sway in the front and a progress rear in the back? I also saw that thing where peoples endlinks broke with the RSB. Was that only on the non SI's?
People aren't breaking the endlinks, they're breaking the mounts. So, it shouldn't matter if it's an Si or not, if it's going to snap it will
![]() But anyways, Si bar front and Progress rear is still better than stock. |
#16 (permalink) | |
If you set the camber correctly with the SI or stiffer front sway bar, I don’t know how by using an LX it could be faster in the turns. It doesn’t make logical sense to me. |
#17 (permalink) | |
While if the rear roll stiffness was excessive it would be possible to 3-wheel, just the progress rear and LX front will not get anywhere near that. |
#18 (permalink) | |
JPK
a perfect example is the realtime acura rsx...over 150 000 dollar car and the slightest inkling of throttle liftoff the rear end rotates and causes oversteer...it takes a profressional skilled driver to master that fwd setup but when it works it WORKS... Just letting you know there are plenty threads on suspension theory, toe, camber caster, alignment specs all stickies....please read those and you will most likely find the answer yourself in which you will learn more then just asking people for the answer! |
#20 (permalink) | ||
I remember autoweek tested some $hitbox and got the rear wheel to lift off in the slalom. That what gave me the idea of balancing the front and rear sway bars. Edit: I've got more reading to do. Quote:
| Si Front and Rear Sways on DX/LX/EX | cojaro | Suspension | 225 | 02-02-2012 12:39 PM |
| Si Front & Rear Sways on an EX Sedan | iVTEC | Suspension and Brakes | 253 | 01-03-2012 11:38 AM |
| ties or sways?? | nvmyrd4 | Mechanical Problems & Technical Chat | 1 | 11-26-2008 11:53 PM |
