#42 (permalink) |
Asif El-Mubaslat
Oh man are those the people from unique whips? I can't stand them! All they ever do is put rims and stereos in cars...Once they put ugly rims and yellow tint on a lambo! They will probably take out your camber arms and install some woofers...then a woofer temp. gauge on the a pillar for when you are "woofing" at like 37 PSI
#44 (permalink) | |
![]() Join Date: Jul 2007
i saw mine last night. Just waiting on the insertAnd Solo - you know you and moose would work on race cars/ your cars all year round if you weren't in canada
#45 (permalink) |
Victor (S. FL Member #28)
Corsport sells a rear camber bracket and bushing set.
CorSport Online Store: SPC Performance - 67465 So let me get this straight someone here said you need a camber kit no matter what kind of drop you do... I know of plenty of HFP Suspension guys (1 inch drop all around), with NO CAMBER KITS, they just go get their car aligned to stock specs. Couldn't you just do this with Tein S-techs? Get a stock alignment. Edit: Obviously if you want to handle better you don't get a stock alignment, but this is just to answer the OP's question. Last edited by APupNamedSmokey; 12-12-2008 at 11:48 AM. |
#46 (permalink) | |
Tod
They're just saying that you can't fix the camber without one, I know that for me a 1" drop would probably give me about the amount of neg camber I would want! (Though I would still get a kit in case I wanted more) |
#49 (permalink) |
time iz money, so iz $peed
there might be some truth 2 this because my cousin who works@ a auto shop told me if i got teins i wouldnt need a camber kit because those springs were thicker. however he did mention alignment though. so is there any truth 2 this?
#50 (permalink) | |
AS SOON as you lower a car you do two things to the suspension -Gain (add) negative camber, with the rear gaining more relative to the front -When camber changes ....SO DOES Toe. Toe Distroys tires ... So YES you need an alignment to correct toe at the very least WHEN you raise or Lower a car ... PERIOD ... A $40 alignmnet is cheaper than 2-4 new tires. If you want to correct / change the camber, then you need Camber kits. Lots of rear camber and not much front makes hte car understeer like a pig. So if you want you car to handle nicely, you need to ADD camber up front, and reduce the camber out back. Moose |
#56 (permalink) | |
Tod
Getting the alignment was a good idea though, because more often than not it's the toe settings (ater a drop) that are out of whack that destroy tires... |
#57 (permalink) | ||
Where did you get the car aligned..? If you take it to a no-name shop or honda they will just put it within factory specs, which allow toe and wandering camber. Having an alignment done, and having it done properly are two different things. You should specifiy you want 0 toe front and rear.. or they will just leave it around factory specs. |
#58 (permalink) | |
Si-Onara
Jeremy
I had SPC camber kits front and rear on my 07 Si and that Junk changed constantly. Every time i brought it in for another alignment it was completely off. I have a Friend that is a Really good Honda tech and he set the settings for me |
#59 (permalink) | |
The factory specs are as follows. ( taken from highrev's post) Camber Front 0 º 00 '±30 ' Rear -1 º 30 '+1 º 05 '-0 º 45 ' Caster Front 7 º 00 '±1 º Total toe-in Front 0±2 mm (0±0.08 in.) Rear 2+2-1 mm (0.08+0.08-0.04 in.) They will cause tire wear.. |
#60 (permalink) | |
Si-Onara
Jeremy
Just leave it alone at those settings and get the toe 0 out on all 4 corners or would you suggest getting another brand camber arm for the rear? Me personally i thought the car feel nicely with the negative camber and the settings have been consistant |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/130648-camber-kits-waste-money.html
| want to know if i made the right decision - ClubIntegra.com - Acura Integra Forum | This thread | Refback | 08-30-2011 03:09 PM | |
| is "H" bar (under the front of car) worth the money..? | FFtouge?? | Suspension and Brakes | 14 | 10-30-2008 08:41 PM |
| "M3 Keep your lunch money, you're gonna need it for gas." | nayilsi | Garage | 23 | 10-24-2008 10:48 AM |
| Can you ajust rear camber on the "new" camber arms? | pks17 | Suspension and Brakes | 1 | 07-20-2008 05:24 AM |
| Are these a waste of money??? | llckll | Suspension and Brakes | 30 | 11-16-2007 11:24 PM |
| what a waste of money (vid) | hondasi006 | Water Cooler | 29 | 04-24-2007 03:35 AM |
