Old 08-15-2006, 04:00 PM   #1 (permalink)
otsacto's Avatar
Rear shocks blown on EX coupe
Ground-Control gave me a a free kit as part of their final test fit for '06 Civics, and the ride hide was set pretty low. So, its no big surprise that the shocks are blown, but what is interesting to me is that its only the rear shocks, and also they blew very quickly, within about 2 months. They are so bad that the ride is absolute shit with a lot of bounce and clunking, and the shock oil has leaked all over the shock body and lower control arms.
I need to buy new rear shocks, but there are no aftermarket products available. I can get new Honda shocks for around $120 through hondapartsdeals.com but I have a couple of questions...
1) Should I just buy the shock itelf, or do you think I need any thing else with it, like bolts etc?
2)Since the rear shocks are mounted separate from the spring, can I just install it myself, is it just a simple bolt on fix? Or does it need to be done with a specific amount of torque on the bolts? Could I just jack the car up and unbolt the blown shock then replace with the new one? Is it that simple?
I appreciate any help you guys can offer---Brian
otsacto is offline   Reply With Quote
Old 08-15-2006, 05:39 PM   #2 (permalink)
jspecFG's Avatar
if you got the money go full coilovers, besides that wait till nice AF shocks come out, I think I remeber seeing something on this forum about Koni shocks.. best of luck
jspecFG is offline   Reply With Quote
Old 08-15-2006, 06:03 PM   #3 (permalink)
Kurt's Avatar
If you're going to just get Honda ones, get the Si ones at least
Kurt is offline   Reply With Quote
Old 08-16-2006, 03:09 AM   #4 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
You need new bolts as the old ones won't tighten the same.
Old 08-16-2006, 06:05 PM   #5 (permalink)
kenchan's Avatar
i remember seeing the pdf for instruction on how to install the
dealer aftermarket spring/shock kit at www.collegehillshonda.com
read that first and see if it's something you can do on your own.
i would personally use the same bolt/nut if they look okay.
some nuts have a one-time lock feature that will loose its
integrity after it is loosened. even so, you can use locktite
if needed.
shouldn't be hard to do if you have the right tools.
how much of a pig is your car? weight list webby Garage 20 05-01-2008 02:30 PM
civic ex coupe or si? matta Introduction & Pictures 45 02-28-2008 05:38 PM
Rear Seat Removal? (EX Coupe) 1zach4 Do It Yourself Articles 13 06-09-2006 09:52 PM
