lowering springs and shocks vs full coilovers` - 8th Generation Honda Civic Forum
Old 10-22-2008, 07:07 PM   #1 (permalink)
d-rok5987's Avatar
Derek
ok, i am definitley looking for a new suspension setup, my only problem is i dont know what to go with. i know someone who did drifting for a while on just lowering spring and shocks and said it was the best. then i know a lot of guys in town who say full coilover all the way. What i need to know is what is best for daily driving/occasional weekend track warrior and daily driver/time attack and autocross. any help would be awesome.
lowering springs and shocks vs full coilovers........opinions anyone?
d-rok5987 is offline
Old 10-22-2008, 07:11 PM   #2 (permalink)
paolo2k2's Avatar
JPK
honestly the best if a setup that meets your needs which is most likely not a prebuilt coilover setup...a setup you can build would be something like choosing your spring...choosing your strut....there you can select the dampening properties ur spring rate...adjustablitly everything you want and you need. To get started take a look at redshift konis!
paolo2k2 is offline   Reply With Quote
Old 10-22-2008, 07:18 PM   #3 (permalink)
d-rok5987's Avatar
Derek
the redshift konis', cool. Thanks for the quick reply too btw. i didn't think i needed to spend all the money on a full coilover prebuilt setup. really i just want to finish reinforcing my chassis, get a good lowered look, and have more prestigous handling. something easy to build and fun to drive.
d-rok5987 is offline   Reply With Quote
Old 10-23-2008, 02:41 AM   #4 (permalink)
I would just go with coilovers. They have ones that won't break your back and are fine for DD with adjustable dampening. Most people (who i know at least) end up getting coilovers even after buying springs cuz you'll always be wondering how your car will feel/handle with coilovers. I mean if you get a good shock/spring combo, then u can go that route too but if you're just planning on buying springs, I'd go with the coilovers.
tinysumo is offline   Reply With Quote
Old 10-23-2008, 02:59 AM   #5 (permalink)
Ronnn's Avatar
depends on how extreme you want
ofcoz choosing the specific springs and shocks will give you the best handling
but, ask youself how often do you go to track your car? and how often do you drive it around town, then you should get the answer.
Ronnn is offline   Reply With Quote
Old 10-23-2008, 09:01 AM   #6 (permalink)
Xtreme Thunder's Avatar
Joey
http://www.8thcivic.com/forums/suspe...spensions.html
http://www.8thcivic.com/forums/suspe...hock-dyno.html
Tires, Camber, Caster, Toe!!!
All stickied up at the top, they should give you insight on what to go with for what is available in the aftermarket at this point and tips on making even your stock suspension work more agressively.
Xtreme Thunder is offline   Reply With Quote
Stock Shocks And Lowering Springs rickhilbert Garage 9 07-09-2007 01:34 AM
Stock Shocks And Lowering Springs rickhilbert Garage 1 07-08-2007 06:07 PM
Lowering springs with stock si shocks? F1fletch Suspension and Brakes 5 01-27-2007 11:14 PM
Everyone is using lowering springs, what about shocks? dlux200sx Suspension and Brakes 20 01-09-2007 08:47 AM
upgrade shocks or go with full coilovers chullen Suspension and Brakes 16 12-08-2006 12:55 PM
