#2 (permalink) | |
Yes you can. It will bolt up. |
yeah but im getting these off another member here, and the price is significantly cheaper than buying it from CHH...so i want to know if these will work before i go out and spend more on them, unless someone knows where to get them cheaper than college hills
#7 (permalink) | |
I have been trying to acquire "hard numbers" on the shock valving for the HFP stuff myself. If ANYTHING, the variations in part numbers is due to the fact the Si is heavier than almost all other Civic models... Therefore it probably has stiffer shocks and spring rates to compensate for this.
Using the Si HFP kit on lower model Civics won't be a problem. Worst case scenario imho: the car won't be lowered as much as it would on the LX/EX HFP kit simply because it doesn't have the static (resting) weight equal to that of the Si. The LX/EX may not compress the springs all that much when installed and lowered back to the ground. I'm not talking huge numbers here, but it may only lower the car 3/4 of an inch instead of the full inch, per se. Anthony "Mario" Crea |
#11 (permalink) |
http://www.collegehillshonda.com/civ...6_exterior.htm
Link to 2 dr part numbers for HFP suspension http://www.collegehillshonda.com/civ...6_exterior.htm Link to 4 dr part numbers. It seems Honda uses a different kit for 4dr auto vs 4dr manual. Hmm. |
| Official 1.8L 1/4 TIMES!!! | Tikolx333 | Civic Coupe And Sedan | 85 | 05-08-2008 04:00 AM |
| Need pics of 17" & 18" HFP on GG EX Coupe | stevieray | Wheel And Tire Upgrades | 2 | 07-24-2006 08:44 PM |
| EX with HFP Package? | jordan | Inside and Out | 19 | 07-02-2006 04:33 PM |
| ex suspension | johnai3 | Civic Coupe And Sedan | 1 | 03-28-2006 12:32 AM |
