Old 06-26-2008, 12:37 PM   #81 (permalink)
It's usualy around 2 fingers....at lease for me.
mellowbob is offline   Reply With Quote
Old 06-26-2008, 12:41 PM   #82 (permalink)
tsltd's Avatar
Hang
if you guys want to "lower" your car then just get aftermarket springs or adjustable coilovers...
the HFP suspension's drop to a lot of people look stock...your paying for the performance not the look...i believe the drop was .8" - 1.0"...
tsltd is offline   Reply With Quote
Old 06-26-2008, 12:51 PM   #83 (permalink)
It does enhance the look of the car. It's one of those 'can put your finger on it' enhancements. Very subtle but overall makes your car more aggressive.
Old 06-26-2008, 12:57 PM   #84 (permalink)
06RREX's Avatar
Drew
It is. But I want to lower my car about an inch. So right now I am debating the HFP or Eibach Pro-Kits. Pro-Kits would be less and give about .2" more of a drop, but the HFP is covered under warranty and handles well.
06RREX is offline   Reply With Quote
Old 06-26-2008, 01:11 PM   #85 (permalink)
tsltd's Avatar
Hang
remember only if you install it by the dealer....but if i were you just get the HFP because you'll eventually have to replace those shocks from just getting lowering springs...also you will handle much much better with HFP...
Old 06-26-2008, 02:51 PM   #86 (permalink)
benmunger's Avatar
hfp is the best... i had it on my 2005 ep3 civic si.
dont do it anyother way unless you are building a track only car.
benmunger is offline   Reply With Quote
Old 06-26-2008, 03:00 PM   #87 (permalink)
Teach me how to take pics
maximus20895's Avatar
Max
So how does the warrenty work.
Is it still in effect if you install is or you do HAVE to to have it installed by the dealer?
P2R TBS/TBGs / Fujita SRI / Skunk2 10th Anv. Knob/Radiator Cap / TWM SS / Cable/Base Bushings /
JDM Dipstick / Auger Boot / StrutKing DP Cover / HFP Front Lip / Cleared Head/Tails /
My Car Build Thread - Amilia
maximus20895 is offline   Reply With Quote
Old 06-26-2008, 03:02 PM   #88 (permalink)
Dustin
welp, installed the HFP this morning.
all went well - just followed the insturctions - definatelly a DIY'er - not worth paying the dealership the $1400 that they quoted me! only took a lil over 3hrs.
drop is slightly noticable - i have only drivin it a few miles on city roads, my ride quality is still there - i really cant tell alot of differance - but then i havent really tested it out - i do still have some body roll - suppose i will install a rear sway..
so all in all, DIY its perty simply you just need the tools that the CHH instructions recommend - i did it with a hydraulic floor jack and 1 jack stand.
Slipp is offline   Reply With Quote
Old 06-26-2008, 03:15 PM   #89 (permalink)
tsltd's Avatar
Hang
nice, any noises while driving, turning?
Old 06-26-2008, 03:16 PM   #90 (permalink)
Dustin
nope - i rode with the radio off and windows down - everything was quiet.
Old 06-26-2008, 05:40 PM   #91 (permalink)
06RREX's Avatar
Drew
post pics!
Old 06-26-2008, 06:16 PM   #92 (permalink)
Dustin
ok. i got some time to drive it around a lil more - it did stiffen my ride up just a little bit and it does handle better on curves - it seems
just got back from an alignment - only adjusted toe b/c i dont have adj camber kits yet.
camber is at:
FL: +0.2" FR: +0.1"
LR: -0.9" RR: -0.5"
so eventually im goign to get adjustable front and rear camber and go with the specs that highrev suggest in his suspension post.
Old 06-26-2008, 11:33 PM   #93 (permalink)
TafEx's Avatar
It seems? So the handling difference isn't that noticeable from stock?
TafEx is online now   Reply With Quote
Old 06-26-2008, 11:37 PM   #94 (permalink)
MutantCheese's Avatar
2008 NFR S2000
Oh, it noticeable. Trust me. Completely different from stock. After driving my hfp installed si for the past 18 months, I finally drove a stock si....big difference.
MutantCheese is offline   Reply With Quote
Old 06-26-2008, 11:41 PM   #95 (permalink)
Dustin
I'm sure it is. I really shouldn't have given my review yet. I installed the suspension this AM and only driven maybe 5 miles on it - trying to take back roads to hit some nice curves.
it did seem more responsive - once i get a chance to test it - maybe if i get to go to the dragon meet; then i could give a better review.
no doubt though, i do not regret the purchase or time to install.
it gave my car a nice drop, a sportier stance
this one curve that i usually take at about 75mph... with stock suspension, my car felt loose, like i was pushing the limits - almost like it was about to loose control - well after i installed the HFP i took the curve at 80 and didnt even realize i was going 80.. so from that i will assume my handling is +++
Old 06-26-2008, 11:44 PM   #96 (permalink)
TafEx's Avatar
Oh, okay. Good to know!
I'm just wondering cause I want this to be the next mod for my EX.
Old 06-27-2008, 12:47 AM   #97 (permalink)
Max
This will be the next mod for my SI
Old 06-27-2008, 12:50 AM   #98 (permalink)
slow4drsi's Avatar
do you need alignment after the install?
slow4drsi is offline   Reply With Quote
Old 06-27-2008, 12:57 AM   #99 (permalink)
asm 06sedan's Avatar
Yusif
Yes you do since you changed mostly the whole syspension.
And if u get HFP syspension install at the dealer Im almost 99% sure that the alingment is included in the price of installation!
asm 06sedan is offline   Reply With Quote
Old 06-27-2008, 03:11 AM   #100 (permalink)
iomatic's Avatar
Alignment on both: front bolts, and a camber arm on the back?
iomatic is offline   Reply With Quote
Comparison between HFP (states) and HFP (JDM) Suspension No. 7 Suspension and Brakes 2 04-06-2008 02:09 PM
Which suspension best for Sedan: Si Coupe Suspension or HFP? mikeymike Suspension and Brakes 16 04-06-2008 02:08 PM
1999ish Integra Type R suspension vs. HFP suspension Illinoisone Suspension and Brakes 3 02-09-2008 10:05 PM
Coupe + HFP 17" + HFP Suspension .. Pix Please illmaticone Suspension and Brakes 7 09-13-2007 02:30 AM
