Old 06-14-2008, 03:42 PM   #21 (permalink)
Endo07si's Avatar
so you guys are saying no aftermarket struts will be needed with the HFP? and if i stick with my 17s will i be ok and/or do i still need 2 wheel alignments?
Endo07si is offline   Reply With Quote
Old 06-14-2008, 03:57 PM   #22 (permalink)
tsltd's Avatar
Hang
anyone know where i can get that 550 +/- price at? CHH got it for 612 + shipping now...
tsltd is offline   Reply With Quote
Old 06-14-2008, 05:23 PM   #23 (permalink)
twix562's Avatar
Tito
And as for the HFP front lip rubbing, you will not rub. You can ask to put your alignment back to stock settings. If you really want the best for your HFP suspension along with 'fun to drive' handling, it's always good to have both the front and rear camber kit and a rear sway bar. I also hear a small front sway bar is the way to go also, if I remembered correctly.
HFP suspension is basically shocks, springs, and struts. Also, I ALWAYS recommend an alignment right after any type of modification towards the suspension.
Have you tried Honda of Temecula on eBay? I bought mine from them and they are great.
twix562 is offline   Reply With Quote
Old 06-14-2008, 05:38 PM   #24 (permalink)
Endo07si's Avatar
oh really? nah i was going to get it from college hills honda since i heard great feedback from their site and does honda provide those front and rear camber kits and rear sway bar? ^^^^
Old 06-14-2008, 05:57 PM   #25 (permalink)
07 fg2's Avatar
Originally Posted by Endo07si View Post
Thanks guys for all the feedback, and after hearing all of your views on how good it is, i pretty much made the decsion to buy it. One thing though, why do I need new tires? arent the michellens good? are u saying that it will ride less rough with 18's or just different tires and if so, which brand? thnx (by the way, I want to keep my stock 17's cause ther powdercoated black and look good, so could I run the HFP without 18's or is it absoultley necessary?)
you don't "need" new tires or any of the other things people have listed. just buy the hfp kit , install it, and drive. if you're going to a track, then you may want the other things like sticky tires and sway bars. on well maintained roads and hiways its amazing, a tad firmer than stock. on pothole riddled side streets . but hey, you will be driving to slow to get a speeding ticket.
07 fg2 is offline   Reply With Quote
Old 06-14-2008, 06:00 PM   #26 (permalink)
07 fg2's Avatar
eBay My World - dchautoparts
i got mine for $536 shipped.
Old 06-14-2008, 06:05 PM   #27 (permalink)
tsltd's Avatar
Hang
they don't got none currently....and all the ones one eBay right now are for coupes...i need SI sedan...
thanks for your help tho!
Old 06-14-2008, 06:46 PM   #28 (permalink)
07 fg2's Avatar
^^ lol! the one time i refer them they're out. i check them all the time and they always had them.
Old 06-14-2008, 07:01 PM   #29 (permalink)
mO 64 StAnG 06's Avatar
Quick question. Can I use the Si coupe HFP suspension on my EX coupe or is it actually different between the two?
Im assuming the Si HFP Susp. would be more stiffer than the one's offered to the LX/EX correct? If so I would rather get the Si HFP equip.
mO 64 StAnG 06 is offline   Reply With Quote
Old 06-14-2008, 07:05 PM   #30 (permalink)
07 fg2's Avatar
^^they are different(si and ex).
Old 06-14-2008, 07:06 PM   #31 (permalink)
Kronos_32's Avatar
^^^they have one specifically for the EX/LX model. I wouldnt think the SI HFP will work well since its designed specifically for it. EBAY has it right now for like $550. you should hop on it.
Kronos_32 is offline   Reply With Quote
Old 06-14-2008, 07:09 PM   #32 (permalink)
I just figured the oly difference between the two would be the one for the Si is stiffer. Because isn't the suspension basically the same between the _X/Si models?
Old 06-14-2008, 07:13 PM   #33 (permalink)
tsltd's Avatar
Hang
thanks i seen that one too...you know if they specify "SI" or "_X" there might be a reason why...the part numbers are different so i dont know...
i just wanna do it right because I got progress springs right now and I thought I eliminated all the poping / clunking noises but apparently they came back again.....or at least i been hearing it again...
so i just wanna go with HFP because its already assembled for you....
eBay has all versions except SI 4DR
Old 06-14-2008, 07:14 PM   #34 (permalink)
CivicBeater's Avatar
Eric
I love my HFP's!
CivicBeater is offline   Reply With Quote
Old 06-14-2008, 07:19 PM   #35 (permalink)
Kronos_32's Avatar
I'll take your progress springs if you sell em maybe haha. And I dont know how the HFP setup goes for sedans and coupes. I beleive it will be the same thing for both and it will fit an FA5, but I may be incorrect. someone please correct me if i am wrong.
edit: I just looked and it said for 2dr and not 4dr. so I guess they dont have it in stock at the moment.
Old 06-14-2008, 07:42 PM   #36 (permalink)
tsltd's Avatar
Hang
yup they are different...called CHH and they said "not interchangable"...they won't be having that 550 special for a while too...
Old 06-14-2008, 07:51 PM   #37 (permalink)
ImBiginKorea's Avatar
I got mine about a month back from chh for 550
BUT IT IS IMPORTANT to buy the proper suspension for you model. All of the spring rates/damping is different between the cars because of different sways, weights etc....
So if you get the fg2's for your fg1, it will be overly stiff in the front because of the extra weight of the k20 and be made for the sways on the si aka it won't be as nice.
--Korea
ImBiginKorea is offline   Reply With Quote
Old 06-14-2008, 11:17 PM   #38 (permalink)
^ Ah ok, that was the answer I was looking for. Thanks.
Old 06-15-2008, 12:19 PM   #39 (permalink)
i love it
Teek20 is offline   Reply With Quote
Old 06-15-2008, 04:10 PM   #40 (permalink)
Endo07si's Avatar
^ok ive heard enough im getting it lol but would you guys recommend anything aftermarket, like sturts or sway bars, after I get the HFP suspension if I only use it mostly on the streets and rarely on the track?
Comparison between HFP (states) and HFP (JDM) Suspension No. 7 Suspension and Brakes 2 04-06-2008 02:09 PM
Which suspension best for Sedan: Si Coupe Suspension or HFP? mikeymike Suspension and Brakes 16 04-06-2008 02:08 PM
1999ish Integra Type R suspension vs. HFP suspension Illinoisone Suspension and Brakes 3 02-09-2008 10:05 PM
Coupe + HFP 17" + HFP Suspension .. Pix Please illmaticone Suspension and Brakes 7 09-13-2007 02:30 AM
