Old 07-21-2008, 01:09 PM   #301 (permalink)
s0opa_Si's Avatar
M i l o
heard some good reviews and some bad ones on the skunks...but the pro-s seems to be perfect for height adjustment and handling.
s0opa_Si is offline   Reply With Quote
Old 07-21-2008, 08:00 PM   #302 (permalink)
packers04's Avatar
Chris
i plan on getting the hfp kit eventually, but was wondering for the time being how much a set of front and rear sway bars and the front strut tower bars would benefit my car's handling.
packers04 is offline   Reply With Quote
Old 07-21-2008, 10:37 PM   #303 (permalink)
ryker's Avatar
rear sway bar is the the first and best mod. Others are just extra $$$ thats not really needed. Front sways are the least effective.
ryker is online now   Reply With Quote
Old 07-21-2008, 11:14 PM   #304 (permalink)
packers04's Avatar
Chris
doesn't the ex have sway bars stock though? or are the aftermarket ones thicker?
Old 07-21-2008, 11:17 PM   #305 (permalink)
iomatic's Avatar
You also need beefier end-links.
iomatic is offline   Reply With Quote
Old 07-22-2008, 12:17 AM   #306 (permalink)
You'll be suprised how much a front sway helps handling on a macpherson strut setup. They seem to be not as affective on older double wishbone suspensions like the older gen civics/integras.
Vincenzo is offline   Reply With Quote
Old 07-22-2008, 03:46 AM   #307 (permalink)
tsltd's Avatar
Hang
someone correct me if im wrong but IIRC the EX has a 11MM RSB, SI has a 17MM RSB, and Progress makes a 22MM RSB....
tsltd is offline   Reply With Quote
Old 07-22-2008, 11:42 AM   #308 (permalink)
Teach me how to take pics
maximus20895's Avatar
Max
^ I believe you are correct sire
P2R TBS/TBGs / Fujita SRI / Skunk2 10th Anv. Knob/Radiator Cap / TWM SS / Cable/Base Bushings /
JDM Dipstick / Auger Boot / StrutKing DP Cover / HFP Front Lip / Cleared Head/Tails /
My Car Build Thread - Amilia
maximus20895 is offline   Reply With Quote
Old 07-25-2008, 11:58 AM   #309 (permalink)
Evan
i know we have moved on from this, but in considering my own hfp upgrade, i started some research on the warranty, this is off AHM owner link:
Is there any warranty on parts that I pay for at my Honda dealer?
Yes. Honda Genuine Parts are covered by a Replacement Parts Limited Warranty. If these parts are installed by a Honda dealer, both the parts and labor are covered for 12 months or 12,000 miles, whichever comes first. If the Genuine Honda parts are purchased from a Honda dealer and installed elsewhere, the parts themselves are covered for 12 months."
just for consideration
emoav8r26 is offline   Reply With Quote
Old 07-25-2008, 12:39 PM   #310 (permalink)
tsltd's Avatar
Hang
^^ that really doesn't make sense shouldn't there be a greater length of warranty time for those who paid for installation vs. installing themselves....
Old 07-25-2008, 11:13 PM   #311 (permalink)
Max
^ you have a point there.
Old 07-26-2008, 12:31 AM   #312 (permalink)
xXxMLEExXx's Avatar
Just received the HFP for the Si Sedan...Need to put it on this weekend.
Awsome deal...
xXxMLEExXx is offline   Reply With Quote
Old 07-26-2008, 10:34 AM   #313 (permalink)
06RREX's Avatar
Drew
more pictures!
06RREX is offline   Reply With Quote
Old 07-26-2008, 01:19 PM   #314 (permalink)
Max
yea, i want pictures of the side of the car so I can see the stance. I know CivicBeater, a guy that has be nominated for ROTM has the HFP Suspension. It looks real good
Old 07-28-2008, 11:32 AM   #315 (permalink)
xXxMLEExXx's Avatar
Installed the suspension last night..took me about 4 hrs.
If I do it again..it would take half. The rear suspension was a bit
pita.
Right now..there's a 1 finger gap in the rear and 2 at the front.
Ride is a little bit stiffer and the body roll reduced.
The suspension comes with everything..even addtional bolts if needed.
Great suspension for less then $550.
Old 07-28-2008, 11:34 AM   #316 (permalink)
TWFA5FTMFW
0720Steve's Avatar
Resident Si Sedan Hater Hater
0720Steve is offline   Reply With Quote
Old 07-28-2008, 05:09 PM   #317 (permalink)
iomatic's Avatar
you need to write it up! Let us know where we can save time.
don't forget every minutae, as if someone who has just enough experience with jackstands would be trying to attempt this.
thanks.
pita.
Old 07-28-2008, 05:27 PM   #318 (permalink)
06RREX's Avatar
Drew
pita.
Old 07-28-2008, 05:32 PM   #319 (permalink)
xXxMLEExXx's Avatar
thanks.
The fronts are really easy...should take no more then an hour.
3 bolts at the top assembly. 1 bolt( brake line ) 1 clip ( wheel sensor )
and 2 bolts at the shocks/control arm. The whole suspension will just
fall down. Put the HFP in and reverse. You're all done.
The rear is a little bit more complicated. Once one jack stands u'll gonna need
the jack. I will try to get the Honda instructions and show what is needed and not.
Old 07-28-2008, 05:35 PM   #320 (permalink)
xXxMLEExXx's Avatar
Originally Posted by 06RREX View Post
Sorry..didn't take pics. My first time trying out on a Civic Si.
It took me about 4.5 hours...if I do it again...it should take no more
then two hours.
Just a note, if you plan to get, camber kits, rear sway bars, and brake lines.
Now is the time with the suspension.
Also, the shocks are from Showa.
Comparison between HFP (states) and HFP (JDM) Suspension No. 7 Suspension and Brakes 2 04-06-2008 02:09 PM
Which suspension best for Sedan: Si Coupe Suspension or HFP? mikeymike Suspension and Brakes 16 04-06-2008 02:08 PM
1999ish Integra Type R suspension vs. HFP suspension Illinoisone Suspension and Brakes 3 02-09-2008 10:05 PM
Coupe + HFP 17" + HFP Suspension .. Pix Please illmaticone Suspension and Brakes 7 09-13-2007 02:30 AM
