TUT: Color Change - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Off Topic > Photoshop
Old 11-16-2006, 01:09 AM   #1 (permalink)
Gizmo's Avatar
TUT: Color Change
In this tutorial I will be teaching you how to change the color of an object.
For the object I will be using a wheel since thats one of the most common things asked to do on this forum.
There are many other ways of going about changing the color of an object, but this is the way Ive learned and have found it easiest.
Step 1.
Open picture you are wanting to edit and select the Magic Wand (circled in red).
Step 2.
Now take the Magic Wand you just click and start clicking on the object that you want to color change.
To add parts of the object press: Shift + Click
To remove parts of the object press: Ctrl + Click
You will also need to mess with the Tolerance (circled in red) to get the right sized areas selected.
Step 3.
The next step once you have all the areas of the object selected is to press (Ctrl+U).
This will bring up your Hues/Saturation Palette.
From here select Colorize (circled in red).
Once that is selected just tinker with the different slides to get the exact color you want.
I will be going with Gold.
Step 4.
From here you will need to click ok to finalize your color change.
Once thats done look over the image to make sure you didnt miss a step.
If you did Repeat Steps 2-3 until everything is the way you want it.
Step 5.
This is the Final Product.
From here just save.
Gizmo is offline
Old 11-16-2006, 01:12 AM   #2 (permalink)
fa1
fa1's Avatar
Woohoo just what I needed. Thanks for the doing my request. This should be stickied.
Old 11-16-2006, 01:13 AM   #3 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
Great tutorial! Tutorials deserve +rep!
Old 03-22-2008, 02:07 AM   #4 (permalink)
portabuddy's Avatar
Thats Mr.Bart to you!
what i like to do instead sometimes is to use the "colour" tool from the drop down menue in the last picture. and setting the flow to ~10-20% then you can replace the colour to how ever you like from the colour pallet...
Life dosn't have a reset button, if it did you may as well turn the game off. -portabuddy
Originally Posted by George Carlin
"Its called the American dream, because you have to be asleep in order to believe in it."
portabuddy is offline   Reply With Quote
Old 08-29-2008, 03:21 AM   #5 (permalink)
heybluguy's Avatar
Wat if u wanna make white
heybluguy is offline   Reply With Quote
Old 08-29-2008, 03:59 AM   #6 (permalink)
heybluguy's Avatar
Nvrmind i figured it out
Old 04-19-2010, 10:19 PM   #7 (permalink)
yukibby88's Avatar
Thank youuu!
yukibby88 is offline   Reply With Quote
Old 04-20-2010, 12:29 AM   #8 (permalink)
portabuddy's Avatar
WOW really, you revivved a two year old thread?!?!?!
I was like? I posted in this...
Old 01-05-2012, 08:48 AM   #9 (permalink)
RevturboJ's Avatar
jevaughn
i like this im going to try this when i go to the mac lab i have some cad design of my model si this will be handy when i want to change my scheme
RevturboJ is offline   Reply With Quote
Old 01-06-2012, 03:56 AM   #10 (permalink)
portabuddy's Avatar
WOW really, you revivved a four year old thread?!?!?!
hahaha
Old 01-06-2012, 03:57 AM   #11 (permalink)
portabuddy's Avatar
damm i feel old
Old 02-04-2012, 03:40 AM   #12 (permalink)
Travis
Great info.
Tman is offline   Reply With Quote
