800,000+ miles and still going strong - 8th Generation Honda Civic Forum
Old 05-21-2008, 04:49 AM   #1 (permalink)
deltatechx's Avatar
Post 800,000+ miles and still going strong
Mileage update: Feb 11, 2011
600,447 miles
I have a 2006 Honda Civic LX sedan 5spd manual, I purchased it used from a local Honda dealer with 22,000 miles on the odometer on 05/26/2007.
It's currently at 203,284 miles, mostly interstate/parkway at 75 mph (occasional 110 + mph) but it still has a lot of city miles as well. Over 90% of the miles were with cargo in the trunk and back seat (rear seat cushion removed for extra height) comparable to 2 passengers in the back.
When I first purchased the car I was getting around 42 mpg but then sometime down the road it dropped to it's current average of 34 mpg (I have no idea why it dropped).
Sometime in June of 2007 I hit a separated tire tread form a semi that was coiled in the middle of the road (newly paved - black) in the middle of the night at approximately 75 mph, it felt like I hit a dog -- it did over $3,000 in damage: front bumper tore in two (replaced), A/C condenser destroyed (replaced), kinked A/C line (replaced), washer reservoir cracked (replaced), passenger side sway bar bracket on lower control arm bent (Dealership actually said the sway bar itself was bent, body shop said otherwise -- bracket was just bent back into place), and internal gearing of the steering rack was damaged (replaced rack assembly).
A deer ran into the passenger side of the car while I was doing about 60 mph. It shattered the rear view mirror glass (absolutely no damage to the housing or the housing paint) and put a good size dent in the rear quarter panel (no damage to the paint).
An oncoming car was across the center line on a curvy back road, our rear view mirrors hit (thank god that's all the contact our cars made) shattering the mirror glass but again, absolutely no damage to the housing or housing paint (these f#ckers are built :P)
Paint is in superb condition, no cracks, chips, or fading. Windshield is another story, countless chips and a half circle crack in the upper passenger side (g*d d@mn dump trucks!!!!!). Factory tint (at least I believe it's factory tint) is in mint condition, no peeling or bubbling. Interior is mint expect for shoe scuff marks on the passenger dash board thanks to my fiance and the silver paint is wearing off of my shift knob. There's no fading of the plastic and the upholstery is still in mint condition.
I have always used Mobile 1 full synthetic 5w20 motor oil with a K&N hp-1010 oil filter, I change the oil approximately 1,000 miles past the maintenance minder. I've just recently started using Lucas oil stabilizer. The only parts I've replaced have been the spark plugs (NGK laser iridiums at 80,000 miles), Duralast Gold - lifetime warranty :P - front brake pads at 120,000 and 180,000 miles (it's impossible to find rear shoes that actually fit from any of the local auto parts stores, they were all too wide -- you can get them from Honda, but they're $15 a piece), Tokico shocks/struts at 180,000 miles (absolutely love them -- still have factory springs though, but plan to drop it with Eibach Sportlines and Skunk2 control arms), and got the rear upper control arms replaced under warranty (new alignment specs) at 190,000 miles (they paid for labor and parts, I had to pay for the alignment) I think the car looks much better with practically zero rear camber, and I love the way it handles now. I have not replaced any belts or hoses yet but will replace them soon along with a coolant and brake flush, new full synthetic gear oil and full synthetic Lucas oil stabilizer for the manual tranny, and a valve clearance adjustment (slight ticking at idle). The engine burns about half a quart of oil per oil change (has always done this since I bought it). Other than the ticking at idle, the engine is silent but idle is a bit rough (I think I need to get the idle speed adjusted -- anyone know how to do this, or should I just have the shop do it?). The factory clutch is still holding strong with no noises from the bearings or tranny.
I absolutely love this car and have had no other problems that I can think of at this time. If you have any questions feel free to ask.
deltatechx is offline
Old 05-21-2008, 05:31 AM   #2 (permalink)
twfa1's Avatar
08 si sedan
picture of car and odometer?
twfa1 is offline   Reply With Quote
Old 05-21-2008, 05:38 AM   #3 (permalink)
DTNguyen107's Avatar
200k!
DTNguyen107 is offline   Reply With Quote
Old 05-21-2008, 06:10 AM   #4 (permalink)
So when you signed up for insurance, did you put down 100k annually? LOL!
habitat is offline   Reply With Quote
Old 05-21-2008, 06:17 AM   #5 (permalink)
Pillar of Objectivity
Special Ringpop's Avatar
That's incredible. You must live in your car to have so many miles on it!
Glad to hear you haven't had any major issues. That's really cool! Have you had to replace the clutch yet?
Special Ringpop is offline   Reply With Quote
Old 05-21-2008, 06:49 AM   #6 (permalink)
Kroze's Avatar
this thread need pics for proof.
Kroze is offline   Reply With Quote
Old 05-21-2008, 07:07 AM   #7 (permalink)
It's probably very safe to assume he delivers cross state for a living.
friedk is offline   Reply With Quote
Old 05-21-2008, 08:53 AM   #8 (permalink)
volvo9's Avatar
Andrew
Do you sleep in it too? haha.
Glad to hear it's holding up so well. The idle could be a few things. The dealer won'd adjust the idle, it's "set" from the factory and controlled by the ecu but with a handheld tuner you can change it.
If it's running rough at idle the first thing I do to my older cars is:
1, change the plugs, you mentioned you changed them at 80k, so you have a lot of miles on them if they haven't been changed again.
2, clean MAF
3, clean throttle body, probrably not an issue on the Civic but it made a huge difference on my Volvo's since crankcase gasses where vented into the intake before the throttle body and gunked it up bad.
4, seafoam and injector cleaner
after that there has always been a significant improvement in idle.
Old 05-21-2008, 09:06 AM   #9 (permalink)
This is crazy, you're saying you drove over 180k miles in less than a year? That averages out to about 500 miles a day! And what Tokico shocks do you have? Tokico currently does not offer anything for the current gen Civic.
a10thunder is offline   Reply With Quote
Old 05-21-2008, 09:17 AM   #10 (permalink)
Chase's Avatar
Chase
Holy Hell man, I thought I had a lot when I put 53k Miles on My Si in 14 months.
Chase is online now   Reply With Quote
Old 05-21-2008, 09:38 AM   #11 (permalink)
faptasic... pew pew pew
rippars's Avatar
Ryan
TOKICO HP Shocks: 06+ Honda Civic 2 and 4 DR!!!!
Old 05-21-2008, 09:39 AM   #12 (permalink)
ryryninja's Avatar
Ry [ the original mahfawker ]
Nice to see its still up and well I'll be hitting 100k in the next 3-4 months
ryryninja is offline   Reply With Quote
Old 05-21-2008, 09:44 AM   #13 (permalink)
myspace.com/assistant_ar
7002iSciviC's Avatar
Andrew
7002iSciviC is offline   Reply With Quote
Old 05-21-2008, 09:59 AM   #14 (permalink)
Will
holy crap.... i've had my SI for just under a year and you have 10x as many miles as I have >.<
PICS! or it didnt happen
icewildabeast is offline   Reply With Quote
Old 05-21-2008, 10:07 AM   #15 (permalink)
CNUco2007's Avatar
Eric
wow... that's alot of miles :-o
CNUco2007 is offline   Reply With Quote
Old 05-21-2008, 10:22 AM   #16 (permalink)
SilverSedanDJVG's Avatar
I have the same car and drive 350 miles a week and still only have 24,000 miles.
SilverSedanDJVG is offline   Reply With Quote
Old 05-21-2008, 10:30 AM   #17 (permalink)
SilverBulletGTP's Avatar
Holy ****, 200,000 miles per year.
SilverBulletGTP is offline   Reply With Quote
Old 05-21-2008, 10:38 AM   #18 (permalink)
Dear lord, where in creation do you live that you've put that many miles on a car? Are you commuting from the quadcities to Chicago every day?
atruhondagrl is offline   Reply With Quote
Old 05-21-2008, 10:41 AM   #19 (permalink)
Zeuceone's Avatar
Pics or it didn't happen
Old 05-21-2008, 10:41 AM   #20 (permalink)
Steve-0-32's Avatar
Steve
ya.... just under but more less.... insane... my 07 ex only has 19k on it.... i feel like my car is a baby....
Steve-0-32 is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/96765-800-000-miles-still-going-strong.html
Honda Civic hits 500,000 Miles! This thread Refback 08-31-2011 03:14 PM
VWVortex.com - Honda Civic hits 500,000 Miles! This thread Refback 08-31-2011 01:34 PM
What to do with used spark plugs? - Bob Is The Oil Guy This thread Refback 08-07-2011 03:56 PM
What to do with used spark plugs? - Bob Is The Oil Guy This thread Refback 08-06-2011 11:25 AM
What to do with used spark plugs? - Bob Is The Oil Guy This thread Refback 08-05-2011 08:01 PM
What to do with used spark plugs? - Bob Is The Oil Guy This thread Refback 08-05-2011 07:40 PM
What to do with used spark plugs? - Bob Is The Oil Guy This thread Refback 08-05-2011 06:48 PM
Proof of Honda Engine Reliability - Page 2 - Vancouver's Top Classifieds and Automotive Forum - REVscene.net This thread Refback 07-28-2011 03:24 PM
????? 675.000 ??. ?? 4d ?? ????? 2,5 ???? &#33; - Club Civic Russia This thread Refback 07-21-2011 05:11 AM
VWVortex.com - Thinking about getting a Prius....... This thread Refback 07-18-2011 06:29 PM
Proof of Honda Engine Reliability - Page 2 - Vancouver's Top Classifieds and Automotive Forum - REVscene.net This thread Refback 07-18-2011 01:29 AM
Proof of Honda Engine Reliability - Page 2 - Vancouver's Top Classifieds and Automotive Forum - REVscene.net This thread Refback 07-10-2011 02:27 PM
????? 675.000 ??. ?? 4d ?? ????? 2,5 ???? &#33; - Club Civic Russia - ???????? 2 Post #0 Refback 06-29-2011 02:39 AM
????? 675.000 ??. ?? 4d ?? ????? 2,5 ???? &#33; - Club Civic Russia - ???????? 3 Post #0 Refback 06-26-2011 04:18 PM
Proof of Honda Engine Reliability - Page 2 - Vancouver's Top Classifieds and Automotive Forum - REVscene.net This thread Refback 06-24-2011 04:28 AM
Forum Quadnet - Le Monde du VTT &bull; Voir le sujet - 1 000 000 km sur une Civic 2006 This thread Refback 06-21-2011 12:51 PM
8th Gen Civic--What's your experience??? - Honda Civic Forum This thread Refback 02-24-2009 12:56 AM
honda civic coupe...300k+ miles - 9thgencorolla.com This thread Refback 01-29-2009 05:33 PM
wanna see something funny? - Club Lexus Forums This thread Refback 12-08-2008 11:55 PM
468K and Counting .. - Page 2 - RedFlagDeals.com Forums This thread Refback 12-05-2008 12:43 PM
Can you say HIGH MILLIAGE !!! - Drive Accord Honda Forums This thread Refback 11-10-2008 07:07 PM
AnandTech - Mileage on a Toyota This thread Refback 07-30-2008 11:03 AM
wanna see something funny? - Club Lexus Forums This thread Refback 05-25-2008 01:29 AM
8th Generation Honda Civic Forum This thread Refback 05-22-2008 01:16 PM
how strong are the SI trannys? k20fg2SI Mechanical Problems & Technical Chat 35 02-26-2013 01:00 AM
How strong is this material? hc806 Garage 18 08-12-2009 09:05 PM
How strong is our oil pans for the Si? AllShowNoGo Garage 3 03-15-2008 04:28 PM
