Old 05-18-2008, 12:36 PM   #1 (permalink)
FijiSan's Avatar
justin
MTF level (!!!!URGENT!!!!)
how can I tell when the MTF is full enough?? i've got both the drain and filler bolts off, and i have a plastic tubing to run from the top of the engine to the filler hole, but how can I tell when it's full?? sorry if this a stupid question
FijiSan is offline   Reply With Quote
Old 05-18-2008, 12:39 PM   #2 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
Make sure the car is on a leveled surface. The moment the fluid starts overflowing out of the fill hole, then it's full. That should be about 1.8 quarts of MTF.
Old 05-18-2008, 12:40 PM   #3 (permalink)
07Nighthawkbp's Avatar
Nate
close the drain hole and start filling it up till you see fluid spill out of the fill hole thats when you know its full
07Nighthawkbp is offline   Reply With Quote
Old 05-18-2008, 12:41 PM   #4 (permalink)
FijiSan's Avatar
justin
thanks for the prompt responses guys, sorry for the nomenclatural mistake on the thread, but i figured it'd be easiest...so basically, let it drain, put the drain bolt back on, fill it up until the fluid runs out of the fill hole??
Old 05-18-2008, 12:47 PM   #5 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
Yeah, that's it.
Old 05-18-2008, 12:49 PM   #6 (permalink)
FijiSan's Avatar
justin
sweet, i'll let everybody know how it goes when i finish, which'll be in about 5 minutes
Old 05-18-2008, 01:01 PM   #7 (permalink)
FijiSan's Avatar
justin
OK new problem.....DIY's are a PITA....it doesn't feel like the Qt of fluid is being emptied, what should i do?
Old 05-18-2008, 03:13 PM   #8 (permalink)
distrbd's Avatar
ken
Pull the tube out a little bit at a time so the end of it is not bellow the fluid level,let gravity do the rest,the best tool for this job is a siphon pump like this one:
SIPHON PUMP KIT Transfer Gasoline, Water and Other - (eBay.ca item 130223247859 end time 19-May-08 20:21:03 EDT)
distrbd is offline   Reply With Quote
Old 05-18-2008, 03:54 PM   #9 (permalink)
FijiSan's Avatar
justin
got it worked out, it took a while, i think i'm gonna invest in one of those pumps for the next one, the only thing that took a while was the actual settling of the fluid itself....it's night and day with the shifts now, it's like butter
Old 05-18-2008, 03:59 PM   #10 (permalink)
Ahhh! Domokun!
Ruthless909's Avatar
4dr WhOrE!!!
This pump works better!
Pelican Parts.com - Sta-Lube Fluid Oil Pump
Ruthless909 is offline   Reply With Quote
Old 05-18-2008, 04:01 PM   #11 (permalink)
Drop Babies not Bombs
Demisedgabe's Avatar
Gabriel
what fluid did u just put? and what did u have before?
Demisedgabe is offline   Reply With Quote
Old 05-18-2008, 04:02 PM   #12 (permalink)
FijiSan's Avatar
justin
royal purple, and it was just the honda factory fluid...i use RP oil too, but i think with the next change i'm gonna go AMsoil all the way, is that many fluid changes bad for the motor?
Royal Purple MTF vs GM Synchromesh MTF? oldskool Civic SI 1 02-08-2008 09:31 AM
AMSOIL MTF or the "new" HONDA MTF? SIcivic07 Mechanical Problems & Technical Chat 7 01-08-2008 07:03 PM
Redline MTF or Amsoil MTF Jardiniboy Civic SI 35 06-22-2007 10:02 AM
Urgent urgent urgent! ;) Can someone answer this within 5 minutes? (Ipod connection) I Vtec, do you? Mechanical Problems & Technical Chat 12 06-21-2007 11:43 AM
Honda mtf or Amsoil mtf? b0yd07 Civic SI 38 06-10-2007 05:16 PM
