Old 05-16-2008, 01:04 AM   #1 (permalink)
cel
Well for a couple wks now i have had the cel coming on and i toke it up to honda and they say its the intake causing the light to come on any thoughts what i could do to get it to stay off?
RALLYRDSI is offline
Old 05-16-2008, 01:07 AM   #2 (permalink)
xrs54's Avatar
what does CEL even mean??, sorry, but i don't own an 8th gen
flam away if ya want!
Originally Posted by Grizam303 View Post
My roommate got a hybrid civic, but I don't regret the si one bit. He gets more MPG, but I get more FPG (fun per gallon). That's kinda why I bought the car.
xrs54 is offline
Old 05-16-2008, 01:09 AM   #3 (permalink)
Kronos_32's Avatar
Thats bullshit. if your Intake was put on even close to correct then it would never throw a cel. Take it off and put it back on then see if it does.
Kronos_32 is offline
Old 05-16-2008, 01:25 AM   #4 (permalink)
fg2!kid's Avatar
エリク eric
check engine light
fg2!kid is offline
Old 05-16-2008, 04:09 PM   #5 (permalink)
The dealership said the ecm is readerin more air comin in and trys to give it more fuel but it overcompensates and throw the code and it just keeps doin that throwin the light
Old 05-16-2008, 04:31 PM   #6 (permalink)
woot, woot
Put the stock intake back on and take it in.
Brad is offline
Old 05-23-2008, 04:32 PM   #7 (permalink)
dannyd86's Avatar
Danny
I searched and couldn't find anything. So im using this thread.
Yesterday I installed my TWM bronzoil shifter cable bushings, and all I did that would be related to this was disconnect the MAF when I removed/installed the airbox. (no i didn't put the key in the ignition with the MAF disconnected.)
When I put everything back together and started the car up I got a CEL. I thought it was weird so I disconnected the battery and then reconnected it. I started it up, and no CEL. I then scanned the ecu and no codes.
What do u think happened? Why would it turn on? Also, even if I do disconnect the battery, if it would have thrown a code, it would still be stored in the ECU right?
Thanks.
dannyd86 is offline
Old 05-23-2008, 04:36 PM   #8 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
it doesnt get stored. everytime you mess with something electrical you need to remove the positive cable. your fine by the way
is Missy a squirter?
Zeuceone is online now
Old 05-23-2008, 06:10 PM   #9 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
You should include what kind of intake you have. Any loose connections in the intake or an air leak can cause a CEL. If your MAF is collecting oil from the filter, it can also throw a CEL. What you should do is double check your connections and buy an electrical contact cleaner to clean the MAF.
Yodums is offline
Old 05-27-2008, 10:17 AM   #10 (permalink)
thanks ill do that today
