K20Z3 Swap problem
Hi Guys, recentely, I got a 07' Si K20Z3 engine from my friend, and I have swapped into my ride which is 07' FA1 with R18A1.
But finally, I couldn't start the engine, I double checked the wiring and everything looks fine. Can anyone give me some advice to work it out? Is it Immobilizer problem? If it is, how can I fix it? P.S. the engine also come with stock 07' Si ECU P.S. I heared that the K-PRO doesn't work on 06+ civic, is that true? Many thanks |
for more infor:
1. I tried to swap back stock FA1 ECU to my ride, I could start the engine 2. I used HDS to check the system and try to flash the key with SI ECU, but HDS appears: a. immobilizer not normal code D3 b. no communication between ECM/PCM and immobilizer unit |
I'm guessing your a tech since you have a HDS? If your using the correct hds password on request it should let you override any key I would say enter All Keys Lost and reprogram any keys you have available the ecu will learn that key try that with s.I. Ecu goodluck
#8 (permalink) | ||
BTW, you definatly have immobilizer issues. if your car ran with teh origianl ECU and not with the K20 ecu, its a communitcation error. make sure that the keys are coded correctly, and the immobilizer and ECU are communicating with the correct codes. if you could reprogrma all of them, chances are your car will run fine. |
#9 (permalink) | |
My SI ECU also come with SI harness, just it seems that HDS can not communicate with SI ECU... I have sent my ride to local honda dealer store, but they can not help me out, either! |
#10 (permalink) | |
My K20Z3 does come with SI ECU, but my HDS can not communicate with SI ECU when I want to flashing the key.... |
#11 (permalink) |
8thcivic Sponsor
The key codes are stored in the top line of the reprogramming for the ECU. Just get the keys coded to the car and it will be fine. PM BLueroadster he has done the rekeying process numerous times before.
There is a hondatech on here lemme find his name.
BUY MY CIVIC |
#13 (permalink) |
8thcivic Sponsor
PM udumkid, he has been sucessful with swapping key codes to different cars and can give help to the dealer techs..
* I Have Finally Done It!!*
BUY MY CIVIC |
| K20z3/tranny/ecu swap. | RonsFG1 | Civic Coupe And Sedan | 2 | 02-15-2008 12:10 AM |
| LX swap with Si trunk problem /w pic | Way2Short | Mechanical Problems & Technical Chat | 3 | 03-22-2007 11:12 AM |
| Auto R18 swap to K20Z3 | zspeedzkwy | Mechanical Problems & Technical Chat | 9 | 11-24-2006 11:04 AM |
