Old 05-15-2008, 04:38 PM   #1 (permalink)
Murderjetz's Avatar
Eric St-Onge
AC Noise
Is it normal for my engine to be making a "whirring" sound when the AC is turned on? I say "engine" because the sound follows the RPMs/sound of the motor.
Here's what happened:
I first noticed this sound a couple weeks ago (although I've only been needing my AC since then), and it didn't seem okay for it to be doing that so I made an appointment at the dealer. Between that time, my AC decided to completely crap out (good thing I already had an appointment set up anyway), at which point the sound stopped, but my AC wasn't blowing cold air either, only the air of the fan.
I brought it in, they told me I needed a freon recharge or something like that, they fixed it, and the AC is back, but so is the strange sound.
it would just seem weird to me that it would be normal for an AC to be making an unpleasant/annoying sound like that.
Murderjetz is offline
Old 05-15-2008, 04:54 PM   #2 (permalink)
Yes, the AC is essentially a compressor driven by a belt connected to your crankshaft. When you turn on the AC the clutch engages and the engine is powering the AC. This is why if you press the AC button while your car is off but in the "ON" position, you get no AC.
habitat is online now
Old 05-15-2008, 11:56 PM   #3 (permalink)
Murderjetz's Avatar
Eric St-Onge
well yeah, I know that the engine powers the AC. What I'm really asking is, is everyone else's AC irritatingly loud? sometimes it's only a very slight sort of humming sound in the background, and that's fine, but often it comes in with a loud DDRRRRR. I know this is probably a really dumb question/subject, I'm sorry. but it just doesn't seem normal to me for the AC to be so noticeably loud, I've never seen any other car that did that.
Old 05-16-2008, 08:34 AM   #4 (permalink)
volvo9's Avatar
Andrew
When I worked for Acura, all of the new cars a/c and all of the newer Honda's ac compressors made that same loud DRRRRT sound when the a/c was first turned on after not being used for a couple of days, so when my Si did it i wasn't alarmed at all.
The compressor will make a light whirring sound when it's on that changes with engine rpm, but if it's loud then you should get it checked out.
volvo9 is offline
Old 05-16-2008, 09:06 AM   #5 (permalink)
Murderjetz's Avatar
Eric St-Onge
I see...
so should it quiet down after using it for a while? it's still doing it now after three days of on and off usage.
Old 05-16-2008, 09:22 AM   #6 (permalink)
volvo9's Avatar
Andrew
I see...
The whirr, or the funky noise when it turns on? I don't think that BRRRRT noise will ever go away, I literally heard it on every new honda made vehicle at the dealer, but only after the ac was off for a while.
The whirr will also always be there, I don't have my Si anymore but even my current car makes a light whirr noise from the compressor that I can pretty easily hear when revving it lightly in the driveway. But like I said earlier, if it's actually pretty loud, then there could be a problem.
volvo9 is offline
Squeek noise with ac on Bandit03 Mechanical Problems & Technical Chat 1 04-23-2008 07:34 PM
AC makes noise and doens't work Murderjetz Mechanical Problems & Technical Chat 4 04-15-2008 06:43 PM
AC temp reading when max ac is on FG2z_K Mechanical Problems & Technical Chat 7 10-11-2007 05:08 PM
How to turn off the AC when the AC is off? dlux200sx Mechanical Problems & Technical Chat 3 05-16-2007 03:41 AM
AC clunking noise at startup FG Two Mechanical Problems & Technical Chat 7 07-12-2006 11:24 PM
